AC forklift model 80 type G
goodenough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goodenough Quote  Post ReplyReply Direct Link To This Post Topic: AC forklift model 80 type G
    Posted: 10 Jun 2021 at 12:26pm
The fork lift will fire but refuses to idle. Tank is full batteries fully charged. Just looking for any advise or incite on what could be causing this.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2021 at 3:38pm
It could be the carburetor is partially plugged, a tired fuel pump, a serious vacuum leak or the timing is out, however, the latter is not likely if it was running OK previously and nobody has touched the setting. Good luck in your trouble shooting. I had a car once that wouldn't idle but would run with enough gas pedal... turned out to be water in the gas.
This page was generated in 0.288 seconds.
