Woods Mowers - Online Parts? |
modirt
Joined: 18 Jul 2018 Location: Missouri Points: 9456 |
Topic: Woods Mowers - Online Parts?Posted: 09 Jun 2021 at 12:36pm |
Found a decent deal on an older Woods 3 point finish mower.....an RM306. But it needs some parts in the form of some idler bearings and blade parts stack. All the cup washers and slip washers. Found blades and belt, but no good without all the rest. Also need to figure out how to rig the center link lift chains. Are these available on ebay or where? Nearest Woods dealer to me is 50 miles plus.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4942 |
Posted: 09 Jun 2021 at 1:24pm |
Howard, Messicks Tractor are a great bunch to deal with, I get most all my Kubota and Ford parts from them. They ship quick and are helpful if you have to call just enter 306 in the search and pick which version you have, your tag should have the version# following the model stamping |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
modirt
Posted: 09 Jun 2021 at 3:54pm |
Have never ordered from Messicks, but use their online parts books all the time for my NH equipment. May give them a try. Have printed the parts diagram and parts list, and it looks like they have most of the parts I need. As luck would have it, one of the bearings I need is for the idler pulley used to tension the belt. It appears the pulley I have has been changed to a new one.....that costs $100 (ouchy), plus you still gotta buy the bearing. And the only bearing they show is for the new one. Call may be in order to clarify.
modirt
Posted: 09 Jun 2021 at 3:56pm |
Another question for you Woods mower guys......blades on it were worn down clubs.....but had a high lift sail. New replacement blades I found are flat.....no lift at all. Are those gonna work?
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90845 |
Posted: 09 Jun 2021 at 3:59pm |
woods did not make bearings... if you can disassemble the pulley and get the bearing size, you can replace'
steve(ill)
Posted: 09 Jun 2021 at 4:00pm |
my blades are flat... ok
modirt
Posted: 09 Jun 2021 at 4:04pm |
Got a Motions Industry storefront nearby. May take the idler to them to see what they can find. The modern era is good about some things, but bad about others. Parts counter guys (or in some cases boys and girls.....out of diapers but not by much) can only find it on a computer......not back in the isles.
modirt
Posted: 09 Jun 2021 at 4:09pm |
Nuther odd thing I found. Middle spindle did not have a blade on it, nor did it have the stack of blade bushings, washers, discs, etc. Middle spindle also does not match the outside two, both of which have blades held on by left hand thread bolts. Single middle spindle has right hand thread. Wondering if that is why miss-matched middle spindle is missing a blade and washers? Is that gonna spin off and go flying?
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1834 |
Posted: 09 Jun 2021 at 4:31pm |
I would say mismatched. I have 2 L306 mowers and all the spindles are left hand thread.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 09 Jun 2021 at 4:33pm |
Probably best to replace the middle spindle with a left handed one. I had a 59 mower and couldn't get the belt to hold up running it right handed on my CA. I bought left handed blades and re-routed the belt the way it's supposed to be for the CA, than used an impact on the blade bolts. I lost one blade while mowing with it for 10 years, and that was probably because I hadn't sharpened them for a long while and it happened to have worked loose. |
john(MI)
Posted: 10 Jun 2021 at 4:09pm |
The blades online are junk. The only good blades I ever found were from the Woods dealer. The ones online are about half the thickness of true woods blades. I got the idler pulley bearing from the woods dealer as well.
HD6GTOM
Posted: 13 Jun 2021 at 11:01pm |
Left handed bolts on the dang blades. No wonder I've never been able to get the dand things off. Will give them another try this week.
CTuckerNWIL
Posted: 15 Jun 2021 at 8:10pm |
