180 Allis Turbo
jrbynf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrbynf Quote  Post ReplyReply Direct Link To This Post Topic: 180 Allis Turbo
    Posted: 01 Jun 2021 at 2:02pm
Question for the experts.  What is involved in adding an engine oil cooler to a 180 allis.  I am rebuilding the 2800 engine and adding a turbo and would like the oil cooler.  I understand the water pump is different and there appears to be a factory blockage in the 190s that allow the oil to flow through the oil cooler.   What would be involved in setting up a 2800 factory block to run an oil cooler?  Thanks everyone
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2021 at 6:10pm
The easiest would be get an oil cooler from the K/F-2/6000 series 4 cyl turbo engine and run two heater hoses to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrbynf Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2021 at 8:03pm
That seems like a very sound idea. Could likely be mounted in front of the radiator and would probably provide more cooling capacity than a unit on a 190xt or 200. Where would be the best place to tap into the oil pressure for high and low pressure sides?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2021 at 8:12pm
The engine oil cooler I am referring to raises the engine oil filter up 2 1/2" to 3 inches and sits right on the existing engine oil filter base. I'd have to make sure there was room for the filter to move up that high ( hood or intake manifold in the way?) but if there is room, a 5/8" heater hose can come from the right side of the block to the cooler and another hose goes from the cooler to the thermostat housing.
This page was generated in 0.176 seconds.
