715 TLB Torque Converter / Clutch pack
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: 715 TLB Torque Converter / Clutch pack
    Posted: 25 May 2021 at 11:19am
Just found out that the torque converter as well as the fwd/rev section used by AC, units used in the construction machines also was used in  MARINE use by others .
A torque converter is one common part as is the clutch pack itself
 Has a large spectrum of different power units that used this common application .
I know a while back someone was searching for a torque converter - and it seems no outfit dealing with construction equipment had one - now evidently there is another source to look for parts outside the common sources one thinks of .
Now thinking back to when i was in the Navy and aboard a Carrier - there were several 40' motor launch boats aboard - using Detroit 6-71 power units and a fwd/reverse unit as well as torque converter involved .
Edited by Coke-in-MN - 25 May 2021 at 11:20am
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 6:04pm
Useful information, thanks.
