HD5 Fuel restrictor
cowrider View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowrider Quote  Post ReplyReply Direct Link To This Post Topic: HD5 Fuel restrictor
    Posted: 18 May 2021 at 8:58am
I have a HD5 that I've had some time but haven't used. Tinker on it once in a while. Wanted to use it recently and found a few problems that need resolving. Starts easy but under the slightest load blows black smoke and losses power. Removed the air cleaner and it was a mess, dirt clogged the mesh. Took a while but got it cleaned up nice. Still the same with it back in. Thought maybe it was clogged worse than I thought so tried running for a short bit with it disconnected, no difference, hooked back up. Gauges were all inop so I replaced them. I found with the new gauges that the thermostat is missing or stuck open, temp doesn't raise until it is shut down. Fuel pressure is 6-8 psi at idle and only 20 psi at full throttle. Where the restrictor should be on the block is a straight fitting. Is there a source for the restrictor or a way for making one?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 9:50am
easiest thing would be solder the fitting shut and drill to size specified in owners manual.  should be 30 -45 lbs fuel pressure
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowrider Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 10:52am
I have the service and owners manuals but don't see what size the hole should be. I took a look and found that there is a thermostat in the dozer and it is a 180 deg as it should be, will replace it. I found that the gasket that had been used covered the bypass hole, should it be covered or open? I would think open.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 2:24pm
Perhaps the blower emergency shutoff is partially or completely closed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 7:08pm
there is no restrictor in the fuel line per-say as the flow from pump also is the cooling for the injectors - (why there are 2 lines ) as fuel passes through injectors it returns to tank and the only restrictor or anything is the diaphragm on back of stock fuel pressure gauge as the gauge would read pulsing caused when injectors stop flow when they are being operated by cam and plunger in injector is depressed .
 Fuel pressure is created at pump and will vary as speed of engine changes - that's normal Also if oil bath air cleaner is not kept clean in both the oil in bowl and the element itself they need to be washed thoroughly and kept clean .
 Remove element , soak in diesel or gas or a solvent to make sure it's clean and flows air without restriction - use proper weight oil (filled to line in cup) as it's required .
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 8:16pm
It could be the emergency blower trap and could be the fuel filter and about the thermostat gasquet am't sure but the hole have to be plugg because some oil is going in coolant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowrider Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 8:25pm
I have cleaned the oil bath filter by soaking in diesel. Problem does not change with filter disconnected from intake and running open, not a filter problem as I had thought at first. There is a restrictor  in the return line as per parts manual item #27 page 36. I replaced the defective fuel pressure gauge with Ametek USG 0-60 PSI 2'' Pressure Gauge. I needed to file the opening a little to fit, screw holes lined up. I am missing the restrictor for the gauge and it does pulse but not bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowrider Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 8:35pm
primary and secondary fuel filters have been changed and bowls cleaned. Oil and filter changed. No oil in antifreeze. There is a hole in the thermostat housing toward the engine that would be below the bleeder on the thermostat cover. Question is, does the gasket cover this hole? I would believe that it shouldn't.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 8:53pm
Did you check the air box drain to see if its plugged with dirt/ mud wasps?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 9:57pm
Hmm that fitting at back of block for fuel line I guess does have restriction , I know I made one but thought it was for bypass oil filter - think i drilled it 1/8"
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 8:57am
as an example.  on my HD20 the restrictor orifice is .058-.063.    of course this is a whole different animal but you can be sure yours will be smaller.
Edited by CAL(KS) - 19 May 2021 at 9:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowrider Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 7:37pm
I filled the end of the barb fitting with solder. Tried to drill it with a 1/16 drill bit but kept breaking the bit, guess I used silver solder. Melted it out and used lead and not as much and that worked. This increased my pressure to about 30psi at full throttle. I am happy with that and leaving it for now.
Replaced the thermostat and cut the gasket with the bleeder hole. Still not coming up to temp on the new gauge, might be bad. Will test with a infrared soon to make sure.
Now to the black smoke and no power. Took off the intake to the blower to check the screen that the parts manual showed. Full of junk and rust. When I was cleaning the air filter I found that the pipe from the filter to the intake was rusted inside. I cleaned and painted this. After cleaning the screen there is no black smoke and lots of power, spins the tracks now.
Now if only my tracks weren't worn out I'd be great. I'll take the wins when I can. Hope this helps someone.
Was even more on this when I took it out.
Cleaned up nice
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 9:45pm
Ha, I'd say that needed to be cleaned! Worn tracks are an issue with a lot of the AC machines since parts are not so readily available. There's an HD-11 a few miles down the road that I've had my eye on, but I know I'd have a ton time and of money in it between engine parts and undercarriage. I hope your HD5 holds up long enough for your purposes.
