Another Pivot ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Another Pivot ??
    Posted: 15 May 2021 at 6:47pm
How big of a concrete pad is required for the "anchorage" point ? What is the biggest "stress" on the anchor point ?
kjs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kjs Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2021 at 7:17pm
About 8 x 8 With post holes in each corner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2021 at 7:29pm
Water comes in at pivot, Corrosion, Erosion from sitting still & dry, while running is only a modest amount of torque on them.
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2021 at 6:25pm
My Mini Pivot, 610' long has a pad about 6'x6'.  A few years ago a 120MPH gust blew it halfway over,  Had to replace some of the pivot pipe but got it back down level.  Make a point to always park it running east and west as the strongest winds seem to come from the west.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2021 at 8:03pm
Is there a "limit" on how many spans a pivot can have? I drove past a field that had 9 spans (this area has fields a mile + long) and wondered what the limitations were for length. Thanks
kjs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kjs Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2021 at 10:52am
The limit on the spans is how much water can you supply to keep crop growing.  I have seen a pivot a half mile long, 1750 gallons per minute. But in a dry year it can't pump enough water to keep the crop supplied.  You would need about 3000+ gallons per minute to keep up.
