7060 rim
kjs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kjs Quote  Post ReplyReply Direct Link To This Post Topic: 7060 rim
    Posted: 12 May 2021 at 7:19pm
I have the rim on a rear tire that is somewhat rotted out around the valve stem hole.  Is it possible to section out a piece and replace?
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 8:54pm
I’ve seen it done successfully
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 8:57pm
I've done it for a 170
kjs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kjs Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 9:01pm
Did you use just mild steel for the repair
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 9:52pm
I cut the patch from a WD rim that was too far gone. After the patch was welded in, I then heated the area where the valve stem goes through and recreated the flat spot. Then drilled the hole for the stem.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 10:25pm
if its a 38" rim,, ya might check the center pivot places for a wrecked wheel, usually the centers are what is bad on them and the stem hole is good, cause they don't run calcium, cut a section and weld it in,,,I jus done this on a 38" spin out wheel,, works good
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2021 at 10:28pm
have new ones
