For the Pilots on here, a friendly reminder!
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Topic: For the Pilots on here, a friendly reminder!
    Posted: 12 May 2021 at 8:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2021 at 10:37pm
My instructor/airshow pilot friend Erik Edgren, every time I get lessons or on my bi-annual flight review we have several engine offs on takeoff. He really put it in me to get that nose down right away if engine quits on takeoff.
Mike
Champ pilot.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2021 at 7:40am
Airspeed,Airspeed,Airspeed!  I cant tell you how many times I have heard that.  Still a scary thought to have an engine out on take off.  About 20 years ago a 182 full of skydivers spun in after an engine out on take off.  Still makes no sense, there are fields perfect to land in everywhere!
 Mike, I'm also a Champ pilot.
Life is simpler when you plow around the stump.
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2021 at 8:20am
Rotor RPM and airspeed in UH-1/UH-60 helicopters for autorotation.   Lower collective immediately to maintain rotor and then adjust airspeed.  Around 70 knots in the UH-1 and 80 in the UH-60 gave the best glide distance and having rotor rpm to complete the autorotation.  There is some ability to shorten or extend glide distance but generally landing will be within a mile or so of engine failure depending on altitude. (float and glide like rocks).  UH-1 could use some rotor RPM to extend glide or avoid an obstacle and it would recover a little.  UH-60 not real quick and may not be able to recover enough for the cushioning at the bottom.
IB (restoring), MF GC1705, MF 2705E
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2021 at 9:17am
while I haven't had power failure on takeoff I do a simulated one evey year when renewing my glider tow check ride its required. I have had partial power loss after take off. at power reduction at pattern  altitude. I wound up with the throttle knob and rod in my hand no way to increase or decrease power. had to pull mixture and deadstick land. not a big problem, in my pacer it glides like a rock so I do a power off on most flights of more than one landing.
This page was generated in 0.953 seconds.
