Buzz saw blade speed |
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Topic: Buzz saw blade speedPosted: 06 May 2021 at 9:34pm |
What RPM should a 18" buzz saw turn at?
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90892 |
Posted: 06 May 2021 at 10:07pm |
To cut wood a blade tip ( tooth) needs to run approx 150 feet per second...
18 inch is 4.7 feet around the outside ( circumference) 150 ft / 4.7 ft = 32 rev per second 32 x 60 = 1900 RPM running a little faster cant hurt, .... figure 2000 RPM as a " good" speed.
littlemarv
Posted: 06 May 2021 at 10:10pm |
Perfect, thanks. Exactly what I was looking for.
steve(ill)
Posted: 06 May 2021 at 10:14pm |
the 1900 rpm is for an older well used saw ( sawmill...).... a newer unit might run 2000 - 2400 rpm as the "sweet spot) ...... do NOT go to 3000 RPM on an 18 inch saw.
littlemarv
Posted: 07 May 2021 at 9:13am |
OK, thanks. I have a handheld tach and will get it dialed in.
allischalmerguy
Joined: 11 Sep 2009 Location: Deep River, IA Points: 2895 |
Posted: 13 May 2021 at 10:41pm |
I have always thought having a buzz saw would be nice help.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 16 May 2021 at 8:42pm |
I used to run a 30" buzz saw on Dads old 35 wc. ran it half throttle and worked fine. ---- smaller blade would have to run faster.
