Tires
D14JIM14 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Topic: Tires
    Posted: 04 May 2021 at 7:55am
If you have a 13.6-28 on one side and a 14.9-28 on the other what will be the height difference ?
Less air inv14.9 and more in 13.6 I assume will compensate some . Not going to be pulling loads .
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 8:42am
13.6 to 14.9 is 1.3 inches ..........thats the width... im guessing the sidewall height is 80% of the width so about 1 inch on the radius.......... so the 14.9 is about 2 inches bigger in diameter... rough guess.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 8:50am
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 8:51am
closer to 2.2 inches........... per the chart.
but remember, you are more interested in the RADIUS not diameter... So you need to let out some air so the axle drops about 1 inch on the 14.9 tire side.
Edited by steve(ill) - 04 May 2021 at 8:55am
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 9:36am
Thanks again !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 10:04am
Problem is, there can be a difference in actual diameter between brands. I have seen the time a 13.6 Armstrong was as big of diameter as a 14.9 Goodyear.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 10:47am
14.9 is an old Goodyear on 14 .9 rim 13.6 is is a newer Firestone on 13.6 rim .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 10:49am
They may be closer to the actual same diameter than you think.  If the tractor sits level side-to-side that's the goal.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 12:13pm
Thanks Dr . Just need some thing close that can give g kids a ride ! When I get it running !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 12:31pm
Park on the concrete and measure the distance from the ground up the center of the axle.... ( about 23.5 - 24 inches).
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 12:33pm
Putting a little more air in the shorter tire will raise that side some as well.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 3:53pm
I guess putting the tape measure to each tire will help a lot. As has been said the brand of tire makes a big difference. In the mid 50's when "B'' models came out with 10-24 tires some came with Good Year tires and some with Firestone. The Firestones were very noticeably bigger, both height and width... same numbers on the sidewalls, go figure?
I really don't know how the tire companies justified the difference?  Since then I haven't kept on top too much of what they're doing. Depend on your tape measure for comparison.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2021 at 4:21pm
Went and saw the tire and rim and wheel (power adjust) very good shape
Measures 1" shorter so some air pressure adjustment will make it work .
May sell 14.9 rim or keep for later . Have extra wheel now . Also may sell 2 weights . Anyway will put it on tomorrow.
Thanks for all the posts !!!
Jim
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2021 at 2:35pm
I got the 13.6 28 mounted and with the extra tread and 14 lbs pressure versus 10 lbs in the 14.9 tire the center axles measure 24.25 inches to center of axle from concrete floor of my shop.
Looks ok for my use . Thanks to all the posts !
Jim
Edited by D14JIM14 - 05 May 2021 at 2:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2021 at 3:39pm
Clap   Clap   Thumbs Up
