7030 hydraulic issue
stollerfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stollerfarms Quote  Post ReplyReply Direct Link To This Post Topic: 7030 hydraulic issue
    Posted: 01 May 2021 at 8:18pm
I had power steering an remote hydraulics go out at the same time. Back story is pump went out an the problem was a piston head broke off an stuck swash plate.
I had another pump that was bad so I made 1 work out of 2. After I put it together it worked for about 30 hrs an quit.
Symptom are no remotes an power steering cavitation
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 8:47pm
The power steering pump charges the piston pump, so if you didn't take it apart and at least inspect it, there may be trouble. Using anything but an AGCO set of hydraulic filters is asking for problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stollerfarms Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 9:41pm
Thanks dr allis I have read that also, what is a good contact for AGCO filters? I took both pumps apart an no visual issue, the one thing I did do was put Carquest filters in
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 6:55am
I would say 30 hours is about time for a aftermarket filter to collapse       MACK.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 8:46am
An AGCO dealer is a great place to start.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote stollerfarms Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 9:27am
I was hoping to get a name of someone in the Midwest an pay for shipping cause the closest AGCO guys don’t help much
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 1:35pm
Hillbill's Diesel, (308) 497-2424. They ship all over the world.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 4:23pm
shipping from the Midwest would be crazy expensive. You need 1-70269921 and 1-70269922
ryan
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 8:47pm
They are all aftermarket filters. Agco don't have a filter factory they just contract them made.
'59 D14 '68 170 Diesel '81 7020 40 All Crop
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 8:53pm
BUT, they are made to AGCO's specs and many of these other "after-market" filters may be the right shape and size, but they are too fine of micron and they PLUG easily.  I had this argument with a Customer 25 yrs ago that his hydraulic problem was the brand XXX filters he installed in his 7020 tractor. He absolutely couldn't believe it, but that's what the problem was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 9:25pm
Dr. Allis what problem was he having?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 10:03pm
Starving the gear pump for oil. He drove the tractor 30 miles for me to fix it and I could hear the pump cavitating when he drove in. I told him it sounded like a problem with the left-hand filter door. He told me not to change the filter because it was new. Things went downhill after that. Two new AGCO filters and he was fixed and mad at me for changing his new brand XXX filters and throwing them away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 10:17pm
Wix builds Carquest and AGCO both but that doesn't  mean they are the same. I ran the Carquest for 400hrs in my 8070 with no trouble and changed them for AGCO 2 yrs ago. At least AGCO includes the o-rings. Not arguing,just saying.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 7:54am
I have a 7020 powershift and I use Wix filters. The trans filter seemed to be clogging too easy but I think it was the generic 821 fluid I was using. I changed to the John Deere fluid that is nice and clear. I think that is better.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 11:53am
Been using WIX with clean oil...no problems. So far...
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 12:05pm
my bet is that back when Dr Allis had those problems with filters, many others did too, and the aftermarket companies usually do try to correct issues. They probably thought they were doing a good thing by offering their filter with smaller micron rating, which in theory sounds great, but if it cannot flow the volume, it ends up causing more problems. Hyd systems don't need as small a micron filtering as diesel fuel injection systems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 12:23pm
My bad filter issue was at least 25 yrs ago, but not more than 30 years ago.  I wish I could remember which brand the filters were.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 2:04pm
I'll start something else while we are on that subject. We started selling Wix products where I worked back 2003. I had to go to the Wix factory in North Carolina for a couple days training. They said the micron deal was a basically a scam. That somebody thought it up to sell more filters probably. They said they had to start saying it too because every other filter company was doing it. They said you can't grind up paper and mix it all up and roll out a sheet of it and say it is 10 or 20 micron or whatever. Also they said that as the filter is used and traps particles that the holes keep getting smaller. They said in a way the filter was doing its best filtering about the time you take it off because the holes keep getting smaller. I ask if the filters they made for Carquest and Napa were any different than the Wix and they said the label was the only difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 9:06pm
I'm sill going to buy Agco hydraulic filters for my 70 series tractors.           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote stollerfarms Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 9:18pm
Ordered agco filters, an to my surprise they aren’t much more expensive then wix. so I’ll take it! I did notice it keeps trying to suck the 2in o ring in the tube
Straanger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Straanger Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 9:41pm
Messicks has some really good videos on YouTube where they cut open oem and generic filters to see what the differences are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2021 at 9:57pm
Second Oring keeps sucking into the filter housing ?? which filter?? the LEFT filter ?? Maybe the non-AGCO filter has been too short, not opening the oil door enough....
