180 Hydraulic Sump/PTO Housing Seal
tomanytractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomanytractors Quote  Post ReplyReply Direct Link To This Post Topic: 180 Hydraulic Sump/PTO Housing Seal
    Posted: 28 Apr 2021 at 1:47pm
How do I know that the pto is engaged ( tractor has hydraulic clutch option)  engaging the sliding coupling to prevent it form falling into the power director compartment prior to removing the hydraulic clutch cover between it and the hydraulic sump ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 1:50pm
If you can very easily turn the PTO shaft at the back of the tractor, it isn't connected. If you can turn it but it takes some effort, it is connected and cannot fall loose inside the tractor.
