7020 PTO speed seems slow on 540
Wbenchfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wbenchfarms Quote  Post ReplyReply Direct Link To This Post Topic: 7020 PTO speed seems slow on 540
    Posted: 28 Apr 2021 at 9:05am
Have a new to me 7020. Everything seems to work fine for an old tractor. Have been using it for tillage the last month so other than hydraulics and draw bar, haven't done much else. Hooked to a fertilizer buggy yesterday, and the 540 PTO didn't seem to be running fast enough at rated rpm. I know I need to put a tach on the pto, but is there anything that I should be looking for? PTO brake works, and engages fine. Doesn't seem to slip but haven't had it hooked to anything that needed a lot of torque. Planning on using it on a baler this year, so want to make sure it's all A-OK when the time comes.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 9:51am
Interesting.  Yeah, if you have access to a tachometer, by all means check it out.  It's either correct, or slipping.  And if it's slipping on a fertilizer spreader, it's slipping something awful.  Gear ratio is gear ratio.
I don't know enough about modifications guys do for making pullers......might be somebody messed with the gearing somehow, but sort of doubt it. Don't even know if that would ultimately affect PTO speed or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 10:03am
99.5% sure there's nothing wrong with the PTO. It will only run 610-620  RPM at full throttle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 10:09am
What makes you think it's running slow Wbenchfarms?
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 11:08am
If someone installed the wrong size belt or pulley on the alternator, that could affect the speed your tach shows in the dash. You may not be running the engine as fast as you think. My 7020 doesn't run as fast as the tach in the dash show.
Just a thought.
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wbenchfarms Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 11:14am
Fertilizer didn't seemed to be spreading as wide of a pattern on the 7020 like it did on the other tractor. Driveshaft looked like it was turning slower. Wide open throttle is not much more than where I am running at 2200, so I think the tach is correct.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 11:43am
WOT is around 2500 on my 7000.  I'd imagine the spec would be similar on a 7020?  I'd get a strobe tach and check it against the instrument panel before making any adjustments.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 12:03pm
What is the "other" tractor ?? A 190XT turns 680 RPM at full throttle and that's 10% faster than a 7020.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 2:08pm
Am I the only one that runs 540 equipment at.......540?!LOLWink
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 4:03pm
Flip that shaft around to the 1000 end n that will wake it up !
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 5:03pm
Definitely get a "strobe" tach as hurst said, and be double checking engine RPMs and PTO RPMs.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 8:12am
Nope. My dad ran the Allcrop and bar mower at 540. He would check shaft with "end tach" and pay attention to where that was on the quadrant. Not much else would matter I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wbenchfarms Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 2:55pm
I also spread fertilizer with a JD 2240 and a Zetor 9520 the same day. Going to track down a tach to check it with this weekend, but watching the drive shaft turn just looked slower to my eyes than the other 2 tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 3:52pm
Quiet cabs will do that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 7:08pm
I hardly ever go by the tach- just when the machine sounds good
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wbenchfarms Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 8:13pm
I posted a while back that I thought my PTO speed was slow on my 7020. Finally had a chance to check both the PTO and engine speed against the tach. Dash tach at about 2350, engine speed about 2220, and PTO at 308. Definitely slow. Where do I go from here? Doesn't seem to be slipping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 9:09pm
Dual speed 540/1000 RPM  PTO on that tractor should run 557 RPM @ 2,300 RPM engine speed when on the 540 shaft.  Either your tachometer is reading slow or your PTO clutch is slipping. PTO clutches on those tractors are normally bullet-proof. I've repaired two in 40 years. One was new and had a flaw in the clutch cover casting and the other was a plugged hay grinder...not the fault of the tractor. There are no wrong gears that can be installed. Either a terrible reading tachometer or your clutch is slipping badly.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 9:17pm
You not the only one, but it depends on the implement.
Haybine, baler, manure spreader were at 540
Forage chopper, feed mill, silo blower, stalk chopper, WOT
Self unloading wagons, bale elevator, feed cart, idle or a tad above.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 5:54am
I'd check the spreader.  Some of them can run 540 or 1000.  They flip the drive belts to a different set of pulleys to keep the spinners at the same speed.  If it's set for 1000, but has a 540 shaft, it's going to do what you say its doing.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 6:52am
Well, yes, it depends on the implement.  But I would say, I run several things slower than 540, such as unloading wagon, elevator as you mentioned.  Also do not run manure spreader full speed, I mean, why?  To throw it farther?  Not an important consideration for me.  We have also NEVER run a small square baler at 540, got the rhythm in my head, but couldn't tell you actual RPM, definitely slower than 540.
Forage choppers, blowers, round balers, etc., run at 540.  I guess that's because most of the tractors I grew up on had the PTO mark on the tach where WOT was anyway.  My big Allis will "overspeed", and the tach doesn't work anymore, usually put it where it sounds right, not quite wide open.  I suppose the chopper might run a little faster now days....it's a 1000 RPM unit, tach hasn't worked since before we bought it, want to fix that dang tach one of these days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 7:46am
If the transmission were changed out from a power shift to a power direct or vice versa, would that change the ratio of the PTO as well as the ground speed? Because is does change the actual ground speed, correct?
Leon B Mo
Edited by Leon B MO - 26 May 2021 at 7:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 8:44am
Which transmission makes no difference in PTO gearing.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 9:47am
most balers [small] are rated at plunger strokes per minet not pto rpm
