plumbing
D19allisowner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Topic: plumbing
    Posted: 27 Apr 2021 at 4:28pm
Anyone ever use SharkBite fittings and what is your opinion of them?
If you choose not to decide you still have made a choice.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2021 at 6:46pm
In Omaha they are illegal! That being said, when we demo a bathroom and the plumber is coming tomorrow but his stuff is in our way, we use the shark bite caps! They work well for the short time they are needed!
Greg Kroeker
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2021 at 6:53pm
I loved shark bite caps for remodels. Used them over and over for temporary. I would not use them in a permanent installation as I have seen then leak over time. They are approved in Uniform Plumbing Code but check local jurisdiction if being inspected.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2021 at 8:46pm
They work great, especially for modifications after the initial installation, but they are not inexpensive!
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 3:14am
I have used them only in the fifth wheel campers I have had for repairs and mods with PEX
They have worked great.  Permanent and never a leak.
Great for tight places with virtually no access or wiggle room.  10 Years and holding on the last camper.
None in the home though.
Steve M Ind View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Ind Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 3:50pm
I have used them on Copper to Pex and they have held good for several years.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 6:46pm
I've got one in the basement for 2 or 3 years now.  No problems so far.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 10:22am
I have used for repairs in inaccessable areas they work great on Pex only thing I've used on. kinda expensive but lots cheaper than tearing the camper walls out. I added a 1 gallon pressure tank to my camper in a area you could barley get the tank in. just cut the line setup the tank with sharkbites stuff the tank in and push the lines into the fittings. been holding for 10 years never a drop. the one under my kitchen sink in the house has been 20 years since I installed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 7:16pm
Would not put one in a wall , ceiling , floor or underground but are awfully easy to use and can get you out of a bind . Have seen a few leak over time .
This page was generated in 1.570 seconds.
