190 on a cyclo planter
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: 190 on a cyclo planter
    Posted: 25 Apr 2021 at 7:44am
I have a 4 row International cyclo I use for sweet corn and pumpkins.  I dont want to use the pto pump on the 190.  Will a 190 run a cyclo blower off the remotes?  Or should I hook up to something else?
Thanks!
Life is simpler when you plow around the stump.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2021 at 10:26am
Why not the pto pump?  The one I had used the direct pto driven fan so I don't have any experience  with pto pump but that is what they are for.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2021 at 9:17pm
We used to run a cyclo 6 row on an XT, and you need to PTO pump IMO.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 7:18am
I don't know the numbers but I'm pretty sure your 190 does not have enough hydraulic flow to run that planter
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 7:36am
Using the hydraulic pump on any tractor to power any orbit motor ain't for free. Eventually you will have to spend some $$$$$ on the pump from continuous use like that. Use the PTO pump. That's what it was made for.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 7:07pm
This is in the "ball park" of my earlier post of "over complicating" a planter whether with hydraulics OR electric  blower motors LOLLOL !! Our ground drive JD 7000 is becoming more appealing every day WinkWink !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 7:14pm
Well, you've got a pretty darn good corn planter for sure. They are also famous for being the absolute WORST singulation planter for soybeans !! You haven't figured that out yet ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 7:34pm
What's the track record for a blow job Allis for beans ?? we run a Kinze brush meter for beans on 30" rows , and use an IH 510 drill on 14" rows ( 7" spacing on our drill). I've read that "singulation" on bean seed is moot ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 7:49pm
Allis air planter in soybeans is as good as Kinze brush meters and FAR better than the bean cups of a Deere planter. Singulation is indeed important when you have a Deere bean cup dribble 15 beans to the foot compared to 9 beans to the foot of a Kinze brush meter or an Ac air planter. If you change your ground speed on a Deere bean cup it changes the rate per acre !! Nice design !!
Edited by DrAllis - 26 Apr 2021 at 7:51pm
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 9:19pm
Cyclo's suck! --- fought uncles 400 -- 8 row for 4 years---it however was direct pto drive---no hyd. pump in between. -- still was a nasty planter. one uncle called planting with a shotgun!
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2021 at 1:50am
I like my orange tractors and silver combines but no one holds a candle to the Deere planters and drills. Weather it’s a 7000 from the 70’s or a nearly new 1760 there’s no comparison. We planted beside a 385 with a 7000 few years ago the 7000 was always picket fence stands the 385 not so much. Plant corn with a 1760 vac now and beans with a 7100 both do excellent.
Edited by victoryallis - 27 Apr 2021 at 1:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2021 at 10:26am
The Amish think tractors are too complicated too, but I think I'll stick with them.  Just because YOU don't understand something doesn't mean that its wrong.  I use a DA 385 for corn, a cyclo for beans, and now I'm experimenting with one for sweet corn and pumpkins since its super simple to change out seed.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2021 at 6:58pm
My Allis 330 with 78 units was more accurate than our 7000 for sure. Deere was easier to set depth. I have a White 5100 now. It's accurate and all but it is complicated to set the population and it is very tongue heavy and very clumsy compared to either the Allis or the Deere. The White and Deere for me always picked up rocks that would get stuck in between the lift wheels and a unit. The White was really bad at that until I put special rock guards on it. The Allis never once did that.
Wink
I am a Russian Bot
