New to forum-hydraulic diverter valve?
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Topic: New to forum-hydraulic diverter valve?
    Posted: 24 Apr 2021 at 10:22am
I have a 52 CA with a model 8 trip loader and snap coupler blade. I'd like to mount Both to the tractor without the hydraulics interfering with one another. Is a diverter valve what I'm needing? If so, would I need to reroute the lift cylinders along with the loader cylinders directly to the diverter valve with one line from the pump to the valve? Any recommendations on a good reasonalbly price valve?
Any other suggestions on how to accomplish this?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2021 at 5:27pm
Put a gate valve, in the line going to the lift cyls, for the loader.  Raise the loader to a comfortable height, then close the gate valve, and the rear cyls will raise as they should, normally.  A word of caution, don't raise the loader up very high, keep it low, and you probably will have enough oil left in the reservoir to raise up the rear cyls, without running the pump dry.Wink
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2021 at 8:24am
The valve will need to have a 3500 psi rating. Not many gate valves can handle that. A ball valve would be better and easier to use.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2021 at 9:24am
I have used one of these on my WD for about 20 years.....it's not rated for 3,500 PSI so I can't recommend it. I have seen a few postings on here over the years where other guys are using the same valve. I have it set up so that when the valve is forward, the front bucket is operational and when I pull the lever back,  the back blade is operational. Each attachment remains at whatever position it is in when the valve is moved. Very handy whether moving snow or dirt when you need the back blade to "clean up".
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 6:23pm
thanks for the replies.
Bryan looks like that's what I'm after. I'd like to find one with a higher pressure, however it seems you've had no issues with this one. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2021 at 7:55pm
Some facts. A WD pump was rated at 3400 psi when they were new and in top condition. Most have fallen below 3,000 psi and some are by now even 2,500 or so. A CA is the same pump, so I assume the pressures would be comparable. The only time it ever hits that number is if you fully extend a cylinder and then let the pump hammer until it unloads. Or if you try to pick up something that the loader won't lift, it is unloading.  I have seen this same valve a half dozen times over the years and never seen one fail, so they must be good enough.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 12:08pm
Question on iron pipe and psi. How much will it stand? Looks like in the picture that is what Brain G has.
All the old crawler stuff had 1000 psi on a good day, if everything went wrong maybe 1500 tops. So all the employment stuff was always plummeted with iron pipe. Is that something to be real concerned about if putting a tractor that makes better than 2000 psi on it.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 1:15pm
This how I did mine. Really convenient to have it close.
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 7:39pm
Dr. allis, will the gpm rating make any difference in operation, I see some valves with a higher gpm.
mdm1, I like the nifty lever on yours, do you know what particular valve that is?
Edited by J&J - 29 Apr 2021 at 7:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 7:46pm
GPM's ain't a problem for you !!!  Your pump on a good day is only 4 GPM.
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 8:09pm
ok, so it looks like I'll have to eliminate the factory TEE and then T off the rear lift cylinders from one of the outgoing ports of the selector valve/same for the loader cylinders. Plug up one side of the hold positioning valve on the tractor and the other side have a line going into the selector valve, correct?
I assume it doesn't matter which side of the hold positioning valve you come out of?
Edited by J&J - 29 Apr 2021 at 8:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2021 at 8:26pm
On a WD/WD45 the lift arm cylinders are fed from both sides of the HOLD valve, but only the left side has HOLD control. The right side lifts or lowers only. The left side lifts-holds-lowers. So, not sure how a mighty CA is plumbed.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2021 at 10:49am
I got it from surpluscenter.com. Get a 3 way valve in the size you need. Just make sure you get one with enough rated psi. Works good for me.
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2021 at 5:45pm
Ok, looks like you have a 3 way 2 position (L) ball valve. These are rated @7250 PSI for $25. It seems to do the same function as the selector/diverter valve for $80. Is there any advantage in going with a selector valve vs. a ball valve?
