AC 712S fluids change HELP!
EvanColeman2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EvanColeman2001 Quote  Post ReplyReply Direct Link To This Post Topic: AC 712S fluids change HELP!
    Posted: 21 Apr 2021 at 11:03pm
Im looking to find out what exactly the type of oil or gear oil, or whatever kind if lubricant i need to fill the box that the pto wheel is connected to, the plug is located directly to the front of the inner workings once you lift the seat back, closest to the gear selection. It is almost underneath a few obstacles but its a plug right on the top. If you have any idea what i should fill it with please let me know as it is empty right now
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2021 at 9:54am
I believe what you are referring to is called the 'Bevel Gear Box'.
A shaft drive from the engine, changes direction 90' through the Bevel Gear Box, with Belt Pulleys on the outside.
I use #80/90 in my HB-112.
G
