side grinder
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: side grinder
    Posted: 19 Apr 2021 at 4:30pm
BIL gave me one with a bad cord which I replaced . Also gave me a couple 120Z flap discs . Would these be good for knocking off the rust on old tractor parts ? Been using my drill and 3M scotch brite ? pads . Thanks !
Edited by ACinSC - 19 Apr 2021 at 5:19pm
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 5:34pm
If it's the same flap disc I'm thinking of be careful. They'll take a lot more than rust in a big hurry. They're slightly less aggressive than a grinding disk
Edited by thendrix - 20 Apr 2021 at 6:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 7:05pm
Thanks Tyler !
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 7:28pm
If you use it on something and get it fairly wore out then it works pretty good for removing rust. Still be careful though. That was a trick we used in a mold shop. We saved used sand paper and used sanding disks for finishing. You could use wore out 220 and it cuts more like 400.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 9:07am
Put a cupped wire wheel on it the paint will just fly off.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 10:14am
All of the above methods work and have their place. On my WD project the wire brush works for loose paint and rust on rough surfaces but not well on smooth surfaces with good paint such as the oil pan. The flap disc and scour pads are better but create heat which can warp sheetmetal. Currently using 80 grit on a DA for that and walnut shells for the tightspots.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 3:49pm
Thanks for all the replies . Tried it out today and it's pretty aggressive . Gonna see what Home Depot has soon .
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 5:55pm
A needle scaler works great on rough surfaces
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 6:17pm
Thendrix, I've never seen a grinding fish, does the fish have to be dried before use and will it work in both directions or only one?  Also you say they are pretty aggressive, do you need to wear special gloves or a face shield or anything
Edited by JohnColo - 20 Apr 2021 at 6:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 6:20pm
A grinding fish is a fish with a machinists apron, face shield, safety glasses, and strong enough fins to handle a grinder.
This page was generated in 0.719 seconds.
