8070 shifting problem
JLynch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JLynch Quote  Post ReplyReply Direct Link To This Post Topic: 8070 shifting problem
    Posted: 19 Apr 2021 at 9:57am
Have a 8070 with power shift, it is hard shifting from park to High or Low, and then hard to shift back to Park.
Have to let the tractor roll a little to shift to park,  only 4100 hrs on this tractor, very well maintained. I have tried a few things, like higher RPMs, clutch inching, clutch braking, shift to 1st gear inching ahead, inching in reverse, best that I can come up with is to roll till the shifter moves to neutral position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 10:21am
New shifting cables will reduce the effort required. The Power Shift trans has a "creep" tendency with cold oil. Shifting into reverse (standing still) and applying pressure to the shift lever while lightly feathering the clutch pedal usually allows it to shift into neutral easier. Technique. Have you ever tried to get a 4430 John Deere out of park when on a hill with a load of corn behind it ??  There is technique to that as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JLynch Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 10:28am
Can I adjust the shift cable at all ?
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 10:28am
I had similar issue with 8030, I used the reverse trick and it help me for years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 10:44am
You can kind of prove it to yourself by doing this: holding the brakes and it doesn't want to come out of gear....just shut the engine off.....wait a few seconds.....shift it out of gear. If that works, it is drag of the cold transmission oil. LOW range will be worse than HIGH range. No adjustment of the range shifting cables will cure that. NEW cables will improve it because a new cable is always easier to move than a 40 yr old one.
Edited by DrAllis - 19 Apr 2021 at 10:46am
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 11:01am
  I seen one that had dirt and corn cobs packed fully around the boot and shifter, didnt help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JLynch Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 7:17pm
How big of a job is it to replace the cables ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 7:45pm
Back in 1982-86 I could change one out in a couple of hours. The main cable (large) is the one to change. DID YOU TRY SHUTTING THE ENGINE OFF?? OR USING REVERSE ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 7:59pm
has anyone successfully oiled them before
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 8:38pm
NO. They have a plastic liner inside that is worn out !! The new replacement cable is much lower drag than any old cable. Until one actually makes the swap, they will never believe it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 8:42pm
ok was just wondering
Post Options Post Options   Thanks (0) Thanks(0)   Quote JLynch Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 3:49pm
Tried every think that you said to do, and had no good results, now I have ordered new cables, hope they are easy to replace, do you know of a you tube video to watch ?
7050..8070
