D14 starter??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: D14 starter??
    Posted: 18 Apr 2021 at 7:10pm
Hello.
Dad had the noise cone break today on the starter on our D14. Would the noise cone out of a B interchange. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 7:24pm
No. The "D" series Starter motors had different nose cones. Gotta' be careful with some of those "D" series Delco Starter motors. Some nose cones were special to a particular model Starter motor.  Ran across this years back when I first got back into rebulding these old Delco unit. The drives are different from one another also....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 7:49pm
6 volt starters are different than that later 12 volt starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 8:27pm
thanks. Yes it’s 6 volt
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 8:43pm
?????  Would the ORIGINAL 6 volt starters on the D14 be the same as the B ??  This guy  thinks so .
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 6:17am
Fleabag sellers only want your money. Most couldn't care lees about what might be correct, or work properly
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 7:14am
Wrong!  Probably going by a catalog that's incorrect.  LOL!  Those nose cones are not a "Fits All" kinda' piece although these vendors make it sound like they are till someone purchases one and it doesn't work. Then they can't return it cause' it was installed. Gottcha!!
Steve@B&B
Edited by Steve in NJ - 19 Apr 2021 at 7:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 8:22am
I only asked because we have a few B’s laying around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 8:32am
Steve, i remember a discussion a few years ago that the ANCHOR hole for the ground bolt was drilled in a different location on some noses.... but you think the physical size is different ? .......... I dont know, just asking ... I have several "B" ... no D.
This page was generated in 0.043 seconds.
