AC D21 Punkin Gone Mad pics on Pulloff
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: AC D21 Punkin Gone Mad pics on Pulloff
    Posted: 09 Sep 2010 at 7:24pm
This is kinda farm equipment related , go to PULLOFF. COM under the heading CARNAGE AT WISCONSIN  or something close to that and check out the D21 PUNKIN GONE MAD  as it catches  on fire and blows up , the rack in the injector pump got stuck , shut the fuel + air off but a seal blew in the turbo and it was running on engine oil till she blew ; very good pics , but too bad for a great pulling 21; maybe someone can post a link ??
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 7:46pm
Pictures:
http://www.allinphoto.com/2010%20Pumkin%20Gone%20Mad%20Fire/index.html
Topic:
http://www.pulloff.com/phorum/read.php?2,67742,67742#msg-67742
Back when everything was going right:
[TUBE]O1rk99kNGgk[/TUBE]
Edited by CJohnS MI - 09 Sep 2010 at 7:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 8:21pm
ORANGE POWER!!!!
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 8:26pm
That is a thing of beauty! I sure hope they can rebuild her and continue to show them all how it should be done.
Those photos of the driver sitting in the middle of that fireball are a little unnerving. It looks like he is okay, but I bet that was terrifying. It sounds like there was nothing that could be done to stop the meltdown, all he could do was wait for it to self destruct. I can only imagine how disappointed the owner is at this point.
Edited by redline - 09 Sep 2010 at 8:42pm
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 8:26pm
This happened at the Fulton Co. Fair pull at Wauseon, Ohio. From what i'm told by folks that were there, the wheels were still turning, wide open, full throttle untill it blew.  The injection pump may have failed, but something also let loose in the clutch area and wouldn't stop.  The only thing holding it back from disaster was the chain on the pulling sled.  If anyone has video of this, please post it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 9:00pm
Scott Diuble (owner): "Thank you to all concerned fans, pullers & tech officials about myself and Pumpkin Gone Mad . I’m fine, the tractor is not. We are disassembling to see just how bad the motor is. This is what we do know: Injection pump stuck open not allowing to idle back down. The air flapper was shut (guillotine style) and the dump valve was pulled (both are always checked before pull by tech officials). Accroding to the computer it ran a total of 48 seconds which 10-12 seconds was the actual pull and the rest was sitting there with the tires spinning. The flash fire was oil residue on manifold after the engine finally sopped running. There are no holes in the block and all the connecting rods are still intact. We are suspecting the engine continued to run on engine oil through a turbo / turbos since we only drained out about one gallon of oil. Again thanks for you support and we will see you back on the track--------someday."
