Wanted Loader brackets |
| Author | ||
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Topic: Wanted Loader bracketsPosted: 17 Apr 2021 at 6:44am |
I'm looking to find a pair of the rear mounting brackets for a 400 series loader on a d14/15 tractor. The RH bracket would be 70344904 or 343362. The LH bracket would be 70344905 or 70343363. Even just 1 would be a big help.
Edited by PaulB - 18 Apr 2021 at 6:50am |
| Sponsored Links | ||
DON G
Silver Level Access
Joined: 14 Feb 2014 Location: Lowpoint, IL Points: 419 |
Posted: 17 Apr 2021 at 9:45pm |
I easily made some for D17.
PaulB
Posted: 18 Apr 2021 at 6:51am |
D17 brackets are just a bent piece of angle, completely different from the weldment for a D14/15.
DON G
Silver Level Access
Posted: 18 Apr 2021 at 8:11pm |
OK Paul.
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 18 Apr 2021 at 9:51pm |
This is what the D14/D15 brackets look like.
orangereborn
Posted: 15 May 2021 at 10:01pm |
Paul...Did you get this resolved...Dale
Kenny L.
Posted: 17 May 2021 at 8:11pm |
Here are some pictures of my 415 on my D15II, when I bought it the owner said he bought the tractor and loader new at the same time.
PaulB
Posted: 17 May 2021 at 8:44pm |
Yep, that's what I'm looking for.
What is the size and thickness of the angle that they are made from? Edited by PaulB - 17 May 2021 at 8:46pm |
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Thanks(1)
Posted: 18 May 2021 at 3:55pm |
Paul Took some measurements of the brackets of my 415 loader. Mine are like those in the actual orange pictures, which you note are different from the sketch from the Parts Catalog. The Horizontal piece: 2 1/2 X 3" 10" long L, 3/8" thick, 2 holes 7 1/8" apart. The horizontal side with holes is 3" wide, vertical side is 2 1/2" high. Sloped piece with 'U' bolt: 3 1/2 X 3 1/2" 9 1/2" long, 3/8" thick, welded to Horizontal piece @ 45' 'U' Bolt is 3/4" diam. The welded position of the sloped piece would be critical because the frame is bolted with 3 bolts to the Engine side frame / rail. Probably best to assemble everything in position and tack weld first. HTH Gary |
PaulB
Posted: 18 May 2021 at 7:06pm |
Thanks: That give me something to go on if I'm unable to find a pair.
DON G
Silver Level Access
Posted: 19 May 2021 at 8:22am |
If you can't find a u bolt an angle iron with holes drilled will work on top, then use bolts. |
JimIA
Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1991 |
Posted: 19 May 2021 at 1:54pm |
I think we have some NOS ones here. I will try to get a picture of them.
Jim
JimIA
Posted: 19 May 2021 at 4:20pm |
JimIA
Posted: 19 May 2021 at 4:23pm |
JimIA
Posted: 19 May 2021 at 4:24pm |
Shipping tag number says 387416.
ZachD89
Joined: 24 Dec 2015 Location: Littlestown,PA Points: 703 |
Posted: 19 May 2021 at 6:44pm |
I have a pair of those brackets and did not even know what they are till now.
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
Kenny L.
Posted: 19 May 2021 at 6:49pm |
Show off You been holding out on me again I see.
Kenny L.
Posted: 19 May 2021 at 6:55pm |
Gary thanks for taking the time to measure the bracket, I'm dealing with a leg injury and don't know if I could've got the measurements but would've tried if you didn't post them.
Edited by Kenny L. - 19 May 2021 at 6:56pm |
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1778 |
Posted: 19 May 2021 at 9:05pm |
hahaha! That was pretty awesome of Jim! Just like magic!
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
JimIA
Posted: 19 May 2021 at 11:52pm |
Kenny, I can't give you all my secrets!
Kenny L.
Posted: 20 May 2021 at 6:51am |
I know buddy, you've been good to me over the years with your secrets, see you Saturday.
structures
Joined: 28 Feb 2011 Location: Beggs, OK Points: 336 |
Posted: 16 Apr 2022 at 9:27am |
Gents, I bought a 400 loader with I think 45 brackets. Wondering if either somebody has the D15 brackets for sale or if I could get a little more detail on the U bolts. Is that 7-1/8" spacing (Gary mentions above) on center or inside dimension?
Thanks for the help.
Robert
1964 D15 Series II |
