Woods mid mount mower for AC C
Walter(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walter(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Woods mid mount mower for AC C
    Posted: 15 Apr 2021 at 4:33pm
Looking for the woods L59 belt number and size for a woods mid mount mower for AC model C.  Thanks
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2021 at 6:06pm
Any auto parts store can get you one B width 225 inches long
philkenealy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote philkenealy Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 5:14am
Is B width 5/8"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 6:51am
B – The B stands for a “B” section v-belt. This is considered a “Classic” v-belt style that has a top width of 21/32 (0.656) inches, but is commonly referred to as a 5/8 (0.625) inch belt. The thickness of the belt is 13/32 (0.406) inches.
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 7:17am
On the topic of Woods mowers, I found an older rear mounted Woods finish mower (RM 306), but it is missing a blade and the entire stack of washers and bushings for that blade. Parts diagram shows nearly 12 different part numbers to make up the stack.
Blades and belts seem to be available, but what about the hard parts?
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 8:23am
I’ve tried belts from Woods and from NAPA. Nothing compares to the longevity of the Woods.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 9:14am
so who makes the belts for WOODS ?............ GATES ?  GOODYEAR ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 11:16am
Part # 3652 for the belt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote philkenealy Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 6:29pm
Great info. Thanks guys! I'm ordering one today.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 8:47am
I like woods mowers, but their parts are expensive. Bought a Gates belt at Napa for 1/3 of the woods price. It's still running, I'll buy another if this one goes bad.
When I got the CA/Woods mower it needed some parts. Thought I'd just put a new set of blades on. Reed told me the price, maybe I'll just sharpen the ones I have! Still running them, keep 'em sharp they still cut fine. Will need a new set sometime.
Edited by IBWD MIke - 25 May 2021 at 8:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 9:00am
normally you can buy blades, bearings and belts ... aftermarket for any mower... You just got to look at the quality of what your buying.
GATES and GOODYEAR make great belts..... who-flung-dung bearings from China might be questionable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 12:30pm
Just spoke with my Woods dealer. He isn’t sure how much longer we will be able to get parts for the old decks.
