D17 series 2 questions
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: D17 series 2 questions
    Posted: 13 Apr 2021 at 5:25am
Which is the correct drawbar hoop. The narrow with the straight sides, or the wide one? If the narrow, would one from a WD/WD45 fit?
Also which lift arm latches are supposed to be on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 9:13am
At s/n 24001, they went to the wide drawbar bail. Prior to s/n 24001 they had the narrow bail similar to a WD/WD45. However, a WD/WD45 bail will not fit on a D-17. Also, after 60 years, any bail could be on any D-17 by now, except a series 4, which is unique to it.
Wayne180d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne180d Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 11:10am
Lift arm latches should have the loop and the stabilizer bar I know mine does.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 8:10pm
Snap-Coupler latches over the years.
HD Snap-Coupler Latch (#5) It has a lot more "meat" than any of the earlier versions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 8:12pm
I have some NOS #5 versions available.
