185 Hydraulics Problem |
Rf 185 CH Ohio
Topic: 185 Hydraulics ProblemPosted: 12 Apr 2021 at 6:46pm |
I have a 185 Crop Hustler. It’s a great running tractor but it has developed a hydraulic issue. The steering, transmission, and 3pt lift have all stopped working. If I bleed the hydraulics, via the pump, it will sometimes work for a short period then it stops again.
We have been thinking it’s probably the pump or there is a clog somewhere in the system. Any recommendations or suggestions are much appreciated. Secondly, if it is the pump, will the pump off of a 190xt (gas) fit on the 185? Thanks in advance! |
DrAllis
Posted: 12 Apr 2021 at 7:21pm |
Where are you checking the hydraulic oil level at ?? No, a 190 pump will not work. Has to be a 180 or 185.
MACK
Posted: 12 Apr 2021 at 9:24pm |
x2 out of oil. MACK
