Fiat Allis HD 11B dozer -parts help needed
Bryan Lively View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Lively Quote  Post ReplyReply Direct Link To This Post Topic: Fiat Allis HD 11B dozer -parts help needed
    Posted: 12 Apr 2021 at 2:21pm
Father in law has a Fiat Allis HD 11B dozer with 11000 Series engine, SN 11-24699 on the engine. Has a cracked/broken #2 and #4 Injector line, beyond repair. looking for a source for a new line or someone to make a replacement.
Thanks in advance
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 2:36pm
What pump model your looking fuel lines AMERICAN BOSCH or ROOSA MASTER
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 5:24pm
If you do replace individual lines, make sure the replacements duplicate the length of the originals, exactly.  The reason is is that if one is shorter or longer, you will change the timing, on that cylinder...Wink
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 5:43pm
Should be Roosa Master pump- #2 line 74339559, #4 line 74339561.  I'd try Thill Track and Tractor, Eau Claire WI or Crane and Tractor Parts, Columbus OH first.  I would have these parts too, but shipping from Canada is ridiculous- you could Pm me if the others don't work out.
Might want to check his vibration damper just in case- sometimes the vibration will break the injection lines, especially #1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Lively Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 6:39pm
Thank you for the information gentlemen. It has a Stanadyne rotary pump on it currently. Will this affect the lines required versus a Roosamaster? Thanks again for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 7:27pm
Stanadyne- is the new Roosamaster, should be all the same
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 8:29pm
   I was was pretty sure the boys could help you Brian, you could request to enter the politics forum on here , its way more lively, feisty then the off topic forum you post on occasionally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Lively Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 12:33pm
Thanks for the tip NEVER green to come to this site...everyone has been very helpful and much appreciated!
