Turbo for 7020
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: Turbo for 7020
    Posted: 08 Apr 2021 at 4:34pm
so last sunday I was planting alfalfa and it was pretty dusty and the then the tractor started chattering pretty badly and I found that the hose clamp holding the intake hose on the turbo snapped in half and the hose popped off and was sucking dirt pretty badly. I had only been planting for about 45 mins. my question is what new turbo would be the best for it? I am hoping to avoid cheap chinese garbage, is there a "mordern" upgrade that works well or should I be looking for a reman garett? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 7:08pm
WHICH HOSE ?? The 3 inch diameter hose that goes over the radiator?? or the smaller 2 inch hose that crosses over the top of the valve cover ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 9:44pm
If it was the 3" hose, I would be more concerned about engine than turbo. Turbo will stand more dirt than engine.            MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 10:37am
the hose that came undone was the main intake hose coming from the filter, I am not concerned about the engine as we had the same exact thing happen to a IH 5288 we owned we just replaced the turbo changed filters and oil and away it went for 6000+ hours before we sold it at 11,000 hours. again my question is should I be looking for a more efficient modern turbo or should I stick with a reman of what it has?
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 10:49am
Stick with what it has.  It's an efficient engine and already pushing out 150hp (at the flywheel) from 301 cu inches.  That's pretty good for a tractor engine, especially of that era.  I would spend your money on buying a quality unit designed for it.  A bad turbo can take out an entire engine.  Check with your local diesel shops, they can usually get you a factory reman from AirResearch/Garrett turbo for a reasonable price.  I had to do that on my 7000 10 or so years back when a tree limb caught the muffler and broke the exhaust housing on the turbo.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2021 at 9:42am
I had my turbo rebuilt at a turbo shop.
