E.I for 720
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: E.I for 720
    Posted: 05 Apr 2021 at 9:54pm
Seams like someone on here offered a E.I. For 720? Any suggestions?
Brad in WA View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 5:22am
I'm pretty sure Sandy Lake has them for those engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 8:44pm
Thanks, I will give Brenda a call.
Bird76Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 11:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 8:29am
Wow, looks like I would have to pull the engine out of my 720 to do this mod. Sounds like a winter time project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 8:30am
By the way the kit is $174 ouch!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 2:24pm
Homerun there!!  And quite a bit of work the way it looks.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 3:12pm
Trust me if  you like your 720 . if u do this and spend the money your will luv your 720 afterward . World of difference.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 8:54pm
I believe I'd just use the module that uses your points as a trigger, and removes the heavy electrical load from them, making them last for ages.. A quick and easy modification from the sound of it.
