Allis Loader
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: Allis Loader
    Posted: 09 Sep 2010 at 9:09am
A buddy of mine might buy this thing...what series is it? what do I need to check out? He said its pretty clean and runs and works....whats it worth? I dont know anything about any Allis Loaders....any help is greatly appreciated.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 5:36am
No ideas?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 10:02am
I had a older post with lot of AC machines listed on a web site , with pictures , once you find the model just do auction search for it.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 11:38am
 This machine look like a TL20
PJsomd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PJsomd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 6:18pm
just sold a michigan 75a wich is alot like that witha gas motor and no glass for $3500
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 6:22pm
Scrap yard down the road from me has a unit similar but not same, has not moved in some time but still won't sell it(I asked).  Has 4 cyl. 4-71 Detroit in it but doesn't even try to start even with a good battery(from the yard hand), probably stripped the blower drive at some point and they left it.  Seems it has a smaller cab and more tapered to the top with only two front lamps.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 7:32pm
machine look like a TL12 14 16 20
would need to know what
motor/transmission that in it ?
to narrow  it down
the thing i don`t like about it
when you lift the bucket your stuck
in the cab
http://www.tpaktopc.net/allis_chalmers.htm
HTH
B:=)   Dnoym
OrangeKiwi(NZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 8:20pm
I'd say it's a TL14. I'm sure you can read the number 14 on the bonnet.
Edited by OrangeKiwi(NZ) - 12 Sep 2010 at 9:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 8:20pm
on second look it mite be the
Allis Chalmers TL12 Tractomotive
with the suicide arms on those loaders
and the Michigan 75's and 125's.
here what i found price is to  low imho
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=ac&th=105277
these are closer
http://www.purplewave.com/cgi-bin/mnlist.cgi?100624/8501
B:=)   Dnoym
Lee Bradley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 10:49pm
Click image for larger version    Name: TL-12 1.jpg  Views: 65  Size: 94.1 KB  ID: 60333
Looked this up to check my memory; the TL-12 had the tilt cylinders back beside the engine with pipe links to the bucket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 10:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2010 at 6:58pm
the one in your pic looks smaller...as far as I know my buddy is going to buy it this weekend....I'll get some pics/info when he gets it home....any idea on weight of this thing? I might haul it for him.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
