Dumb questions
squirt239 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote squirt239 Quote  Post ReplyReply Direct Link To This Post Topic: Dumb questions
    Posted: 04 Apr 2021 at 8:20am
I'm new to this...as previously stated. So, I apologize for my ignorance. I have to rookie questions.
1. I have a D14, and just acquired a 3 bottom plow. Will the D14 pull it? I'm familiar with 3 point, but not with the snap coupler. Is there a user's manual on how to do it?
2. I have no weight in/on my wheels. Do I need it? Recently, I had an old timer (I say that respectfully, not as a slam) tell me to put either antifreeze or windshield washer fluid in the inner tubes. Does anyone else do this? I'm trying to avoid calcium for obvious reasons.
Again, I'm a newbie. Forgive my ignorance!
Brett Havlin
Brownsburg, Indiana
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 8:28am
Depends on the soil but around here D-14's are better suited with 2 bottoms. There's newer stuff for in  the wheels thats not calcium. Its not as corrosive. Never heard of using antifreeze or windshield washer solution. You wouldn't gain as much weight using those.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 10:18am
washer fluid is the 2nd most uses around here after calcium.   2 bottom plow tractor.   anti-freeze would be expensive.  maybe U-tube for snap coupler.   i learned on snap coupler, so its 2nd nature to me.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 11:02am
Weight of some sort will certainly help you pull any plow. But 3 bottoms would be a lot no matter what. What size bottoms, 14 or 16 inches? Makes more difference than you might think.
Better to have a setup that goes fairly easy most of the time and have a little reserve for a hill or tough spot than something maxed out from the get go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 12:01pm
Just take one bottom OFF.
Post Options Post Options   Thanks (0) Thanks(0)   Quote squirt239 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 12:02pm
Well, if anyone is interested in a 3 bottom plow here in Indiana...😁
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 12:18pm
Load the rears with Beet Juice.  As was stated, take the third bottom off.  You will then have a fine plowing machine, and some good spare parts for the two bottom plow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote squirt239 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 12:37pm
Good idea! Thanks!
So, no to washer fluid?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 12:44pm
I think what they're saying is washer fluid is great alternative to Cal Chl but is rather expensive. Have never priced beet juice. Neither is as heavy as CC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 12:48pm
Tire place here quit the beet juice. Didn't get full explanation just know they were dissatisfied with it.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 3:30pm
A gallon of washer fluid/antifreeze is at least 8 #'s/ gallon. I have no idea how to do the calculations of tire sq.inches/ fluid volume, but I'll bet the above 2 products are somewhat cheap #'s /$$$ Wink
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 5:28pm
My D14 will pull a 2 bottom snap coupler 16” plow pretty much anywhere, but adding a 3rd bottom it would have to be good soil that is worked every year for it to pull it. I’ve seen D14’s pull 3 bottoms, but it always seemed like more than they wanted. I’d do like the others said and remove 1 bottom, and it should plow great. A good 3 point hitch conversion will pull 3 point plows every bit as good as a snap coupler plow, notice I said a good one, designed like ALLIS did, where the top link goes down to the pulling arms and not to a bracket hooked behind the seat. Just saying if you had a good 3 point plow already or available.
   As far as fluid in tires, yes you will need it or the steel wheel weights, would help quite a bit. There are alternatives to calcium available today, just not as heavy.
To me it depends on how good you maintain your tractor.    I use calcium in mine, no problem, you just have to be vigilant with them, any signs of leakage or loss of pressure, get them repaired immediately. Because it will ruin your expensive rims, so keep a good eye on it. Calcium is all my tire shop installs, they want stock anything else for them and says what I told you, if any leakage or questions of leakage, get it fixed that day or the next. I know , can be a lot of trouble if you need the tractor now, but most people have a second tractor to use.
Good luck with the plowing, a D14 is one of the best plowing tractors I’ve ever used.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 5:45pm
I've pulled a 3 btm plow for 20 years behind 'Troy', my 1st D-14. even turinging over 30 years old 'pastures' ,it does a GREAT job ! 1st thing to do , is take an angle grinder with coarse grit sanding wheels and CLEAN the moldboard and points or whatever you call th steel that goes into the ground and turns dirt over. Shiny and smooooth is what you want.
then adjust the plow using the 'beaming screw'  to set the angle the plow digs into the soil. Adjust the right side arm to getthe correct 'left -right' tilt.
OK, I don't know the correct terms but.. the beauty of the Snap Couple system is that 'setup' only needs to be done ONCE. Heck I've used the other 3 D-14s to pull the blade..NO adjustments needed. THAT is really,really handy for a 'nonfarmer' guy like me !
when done for the season, while the blade is shiny, spraypaint over the shiny areas. Just a light coat, then next spring, hookup and plow.......the ground will wear off the paint in 50-100 feet.
The left rear tire is loaded, right is just air....it's just the combination that allowed all 3 D-14s to have matching tire sizes......
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 7:26pm
A set of D14/15 pie weights might seem expensive to start with, however they won't run down the ditch when you get a flat. also fixing that flat will be much less expensive and no worries about rusting rims.
  Yes, a D14 will be better suited to a 2 bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote squirt239 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 9:01pm
I love this forum.
Thank you everyone for your experience and input. Thank you also for not making me feel stupid for asking newbie rookie questions!
You guys are awesome!
I don't know of any beet juice available locally. But, I'll check around. I'm not active enough to monitor the tractor for CC leaks, so that's not an option. I'm a career firefighter, and a hobby "farmer." And I use the term farmer EXTREMELY loosely. Hobbyist at best, but more like learning what not to do.
I missed my calling as a farm hand. I've grown up around farms and animals, but never got any education in it. I regret that now.
I have a lot of respect for all of you and your expertise. Thanks again for helping me out with my ventures!
Stay safe and hope you all had a very blessed Resurrection Day!
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 10:06pm
FYI
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 4:37am
A D-14 with a good strong motor and clutch might pull 3-16, but another solution would be 3 14" bottoms...
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 5:31am
If you need the added weight calcium is affordable and available. The rims on our international loader tractor failed after 40 plus years and a number of flats from steel t posts. The cost of the wheels was not that bad. It takes a lot of iron to match the pounds you get with the calcium.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 5:31am
If you go with pie weights, be SURE to inspect your rims NOW for hairline fractures starting at the square bolt mounting holes ! I have 2 or 3 here with the cracks...I assume it's from loose pie weights banging and beating up the rim.
I'd add a section of rubber,maybe 'sill plate gasket' foam,then the weight AND have a lock washer on the nut as well. Then  inspect them 2-3x a year.
I bet the weights ain't cheap to buy..hmm wonder what 'inside liquid' costs ? Bet that ain't cheep eitehr......
Jay
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 8:02am
Local tire place uses windshield washer fluid. It's 8 lbs per so per gallon. Sometimes you can find jugs of the stuff on sale for a $1. That is still 38 or so jugs to get 150 lbs per side.
Charlie
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 11:56am
I pull 3 -14s with my D14 in good soil, mostly creek bottoms. I don't believe it would pull it on rough ground.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 1:55pm
Something to consider, the original poster is new and inexperienced. Not to say he can’t figure it out, heck maybe he’s a total natural. But I still say, better to use something that works easily. You can always grab a little faster gear if things go easy as pie. If he takes one bottom off and the plow pulls like a hot piano wire through butter, put it back on.
According to jay a long time ago, most of his plowing is garden soil that gets plowed several times per year! That’s not really plowing. Yes, he said 30 year pasture went good, but I have to wonder.
Bottom ground, rough ground, sod, hills, ballast, ....so many variables. Can it be done? Sure.
Good luck to the OP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 5:46pm
Jay
Jay, I've seen those hairline cracks, on tractors that never had pie weights on them.  I suspect they had a bad batch, from the factory, at some point!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 5:53pm
The WORST hole you can put  in sheetmetal is SQUARE.. As you flex, twist, etc.. all the stresses concentrate at the corners and cause crack.. Especially since a square hole is PUNCHED and could have imperfections at the corners.  Always better to have ROUND holes unless absolutely necessary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 6:13pm
well I got 'conned' into plowing 2, 1 acre gardens out of pasture today, Troy did very well....1st ,low range.meter said 1.5MPH,I think....no problems 'cept for 2 ROCKS.
It'd have been easier if the landowner hadn't strung a row of grapes across the field....
oh well, light showers now, saw some worms too !
Interesting about the fractures with no weights. I'd always assumed previous owners had  weights on, they'd get a little loose, bang,bang, bang..crack......out of 10 rims, 3 have the cracks. Makes sense about the square hole is bad though !
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 6:53pm
Brett, no problem with the ignorance, that is curable. None of us on here knows everything. I grew up on an Allis B and WD but I still ask questions on this Forum and I have learned a lot. Stupidity on the other hand --- as they taught us in EMT school "there ain't no cure for stupid."
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 10:04pm
Well, are you plowing an acre, a garden, 60 acres?
Post Options Post Options   Thanks (0) Thanks(0)   Quote squirt239 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 6:40am
Haha!!! True statement!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote squirt239 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 6:44am
I'm starting small. Maybe a few acres, depending on how well it goes.
Back story:
I have 92 acres that is family ground. It's mostly wooded and used for hunting. However, since I've been the caretaker, I've cleared 20ish acres into pasture. I'd like to plant a large garden to grow items for the local farmer's market. My wife and I have 3 kids in 4H and would like to see them maybe take it over at some point.
It's more of a dream hobby than a livelihood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 8:14am
You could do a few acres with 2 bottoms and no weights. Start small for the first year and see how it goes.. You can add weight next winter for the following year as needed.. Once you plow the sod and get it done one year, you might find it is easier the second / third year and no weights are needed ?
This page was generated in 0.238 seconds.
