WD-45 maintenance questions
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 maintenance questions
    Posted: 30 Mar 2021 at 6:37pm
Evening everyone, had a friend call me today, his family deer camp was just given a 45 with power steering,
he ordered a owners manual but it’s a week plus out and they wanted to check the fluids, I’ve never sat on one and had no idea, so I’m asking, how many compartments, where to check levels, and what should be in them, can someone enlighten me? As always thanks for any info, I was surprised there wasn’t a owners manual pdf floating around on the net somewhere!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 7:59pm
here is a photo from 10 years ago... and discussion about Universal Tractor fluid
Edited by steve(ill) - 30 Mar 2021 at 8:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 8:03pm
Engine has 6 quarts,
I use SAE 30 above 32 degrees
Transmission has 17 quarts of SAE 80 EP. it is a square plug on the left side of the transmission just in front of the clutch pedal. There are 2 plugs on my WD and would assume on a 45 also. One is for the transmission,differential and one for the clutch. Both compartments use the same oil.
In front of that is hydraulic pump dipstick and fill. SAE 20W 5 quarts.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 8:40pm
The two final drives are in the pan at TD bottom inside the tire. They should have 80-130 gear oil. Remove the plug it should be level full. The steering box under the radiator in the from takes gear oil also. If it leaks out you can fill with corn head grease. Don't use grease gun grease it won't flow down and get to the bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 8:52pm
thanks guys!
Ford 345C TLB
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 9:26pm
I can vouch for the cornhead grease! Non of my tractors' steering gearboxes hold oil, but cornhead grease doesn't leak past the seals.
