Allis WD live hydraulic pump I.D?
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Topic: Allis WD live hydraulic pump I.D?
    Posted: 30 Mar 2021 at 8:38am
Hello all, I spent a fair bit of time searching but came up empty; does anyone know what brand of pump setup this is?
The tractor is a WD with a WD45 engine (and grill) that had a loader on it. I pulled the loader and just plumbed in a remote for the back.
I'm interested to know the flow rate and pressure this system will produce. Pics attached. Matt
Edited by Northern Hoser - 30 Mar 2021 at 8:40am
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 5:54pm
I've the same pump on my dad's 48 WD and I can't think of the company name right now (I think it start with a G) and I think it's 2500 psi I don't know what the flow rate is. Just a heads up if you're lifting something and the engine dyes on you you might have broke the gov weights it has happen twice to me. HTH
Strokendiesel002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strokendiesel002 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 9:50pm
I wonder if that's a Parker- there should be a model number stamped on it. If there's too much paint and you can't make out the stampings I bet you can figure out the specs by measuring it. The higher GPMs are the same diameter, just longer.
https://ph.parker.com/us/en/aluminum-sleeve-bearing-pumps-model-h/h39aa2b
Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 7:30am
Thanks all, still can't find anything more than casting numbers on the pump parts. Anyway, it works pretty well,
Matt
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 10:11am
Looks like an older style Gresen pump.
