720 vs 620
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: 720 vs 620
    Posted: 29 Mar 2021 at 8:24pm
What is the difference ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 8:46pm
Different decals and the 720 came with 3 point hitch, pto. Also a complete line of new implements were made for it.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 9:12pm
620 has 3 point and pto as well.  Basically the same tractor with different decals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 9:22pm
Same motor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 7:01am
The only difference I see in 620 vs the 720 is the decals myself. Drivetrain, attachments and sheetmetal all look the same to me. The 616 is a little different as far as the electrical end of it, and the engine. (CCKA vs CCKB) But I think for the most part, the running gear is also the same as its cousins....
Steve@B&B
Edited by Steve in NJ - 30 Mar 2021 at 7:02am
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 9:11am
720 generally had the heavier duty front axle although some early ones still had the lighter duty axle.  Can tell the difference by the bigger "hats" on the spindles.
IB (restoring), MF GC1705, MF 2705E
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 9:11pm
From what I understand, you could get the heavier from axle with the 620 as well. Not sure how accurate that is, but that's what I was told years back when I first started getting into them.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 9:35pm
I’m going by the AC book of knowledge......
