D grader shift pattern
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Topic: D grader shift pattern
    Posted: 29 Mar 2021 at 7:28pm
I've seen a picture some time ago of the gear shift pattern on a D grader. I'd thought I'd saved it, but now I can't find it. Would someone please post a picture of the D grader's gear shift pattern? Thanks
Edited by PaulB - 29 Mar 2021 at 7:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 5:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 9:55am
WOW!! That's a crazy pattern! Be a tuff one to fiddle with and figure out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 10:05am
That works.  THANKS   I knew where 1st & reverse were as they are about the only two gears the grader has power enough for. Big smile
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 5:54pm
They were geared too fast. They did make a reduction gear box for them but I was never able to find one for mine. It is a good thing the engine had lots of torque because I was often working with engine at a fast idle.
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 7:52am
   Good morning.    If you have the auxiliary transmission, you can drop your ground speed in each gear by 66% (not 10%, not 15%, not 20%; but, 66%). Wow, what a difference this makes on your R P M's.
   My 1967 'D Special' with hydraulic brakes, which will be for sale later this week in Ontario, Canada.     Ross D.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2021 at 4:01pm
Ross !!!  Are you going to sell my baby ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2021 at 3:35pm
Ross, I hated to part with mine but I didn't I didn't think it would fit that well when we moved to a city sized lot or get much use on paved streets. You must be moving?
Robert Z View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Z Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 10:26pm
good day all. I have a D1598. It has been sitting for a long time. It ran when parked but the engine is stuck. Any advise on getting it turning again?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2021 at 5:37am
Assuming it's gas....
basic list....
1-remove plugs
2-add 50/50 mix of acetone and ATF to all cylinders
3-wait a day
4- repeat 2 and 3 for a week
 drain tank and carb, see everything is 'free', charge batteries, etc. while waiting..
5-blow out cylinders,connect battery,try to spin over
6a- no spin, goback to 2-3-4
6b - spins ! add plugs,fresh gas, try to start
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Z Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2021 at 8:34am
Thank you so much. Yes it is a gas.
How much do I put in each time?
Is a ounce to much?
Do I need to worry about getting acetone fumes getting into the crank case?
Or does the ATF stabilize it enough.
RZ
