B&S problem.. |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25262 |
Topic: B&S problem..Posted: 29 Mar 2021 at 7:34am |
OK, neighbours' B&S vtwin, 25 hp, 2002, 488hrs,has a curious and frustrating problem.. Starts and runs at medium high speed, constant, can't vary speed with lever. Everything is conected,even tore carb off to CONFIRM butterfly is there and moves.... If I manually push the linkage from guv to carb up, it'll slow down,but it's 'stiff'. Naturally all this happens AFTER I tore engine apart to install new 'oil pan' gasket and a new starter....so it's 'my fault'. Guv springs are where they're supposed to be, adjusted guv from net... did this 2-3 times. I HATE to think the internals are somehow busted..... if the guv guts were busted, it'd rev to a zillion rpm and kepow ?? Anyone seen this before ?? Any ideas ?? Thanks Jay
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5182 |
Posted: 29 Mar 2021 at 7:50am |
Make sure the cable is connected to the lever still. Don't ask......
Edited by thendrix - 29 Mar 2021 at 7:51am |
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 29 Mar 2021 at 8:55am |
Jay This guy may be able to help you. He has an endless number of Videos on YouTube regarding Small Engines. Gary https://www.youtube.com/watch?v=CV3BcTwLXb8 |
jaybmiller
Posted: 29 Mar 2021 at 9:01am |
yeah, cable's connected....the THROTTLE cable.....sigh..had to CONFIRM that last night.... mechanically everything is as it 'should' be guess I need to put speakers on this PC one day....
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 29 Mar 2021 at 9:33am |
I had a similar problem about 10 years ago.. Could not get to REV UP after disassembly. Thought i must have got the governor WEIGHTS inside caught or broke or ??........... Looked at all the movies on you tube and saw that the ARM that bolts on the OUTSIDE of the governor shaft is very critical in its position.. They had a procedure to rotate the shaft one way, then hold the arm in a specific position, then tighten.. I had it off just a little and made a BIG difference ..... and the governor spring has SEVERAL different possible holes to install... check the internet photos for proper hole.
that governor shaft only moves a little bit, right ?? Maybe 10- 15 degrees, so a little is a LOT ! Edited by steve(ill) - 29 Mar 2021 at 9:34am |
Robert Musgrave
Silver Level Access
Joined: 11 Sep 2009 Location: SE Wisconsin Points: 246 |
Posted: 29 Mar 2021 at 9:40am |
The governor adjustment is critical. Loosen the clamp, turn shaft and hold, and with your THIRD HAND hold the adjustment and re-tighten clamp. Years ago, had the repair manual open to the adjustment page--didn't realize it but page turned itself and was looking at the wrong picture--no matter what I did it was running WOT. Finally, saw that I was on the wrong page--similar diagrams for Vertical and Horizontal shaft engines, different pre-sets (clockwise vs. counterclockwise). R. Musgrave
jaybmiller
Posted: 29 Mar 2021 at 12:34pm |
arrrrrgh, this one's a friggin noghtmare..... 4th time adjusting the guv, 'by the book', BTW vicegrips make a GREAT 3rd hand to keep guv shaft fully CW...... had idle and fast,even inbewteen...great...go for test drive.. arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrgh.. back to med-fast speed and throttle lever has NO effect... Jay it's ONLY the 1st monday of the week but ...can I go back to bed ???
steve(ill)
Posted: 29 Mar 2021 at 4:29pm |
governor controls max rpm, overspeed..... throttle sets the max operating rpm you want and works with the SPRINGS to adjust that... still think it is an adjustment problem.. Maybe a different VERSION of the MANUAL is needed ?
jaybmiller
Posted: 31 Mar 2021 at 5:14am |
arrgh.... downloaed the OFFICIAL B&S rebuild manual, guv details same as the others online.... ...so..... today's job ,once Mr. Sun comes to visit...is to remove from rider, get on bench drain oil, tear it apart as it HAS to be 'something' inside crazy thing is I've done lots of these in the past 3 decades, one just a MONTH before this PITA beastie... maybe someone's telling me something ?? |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4874 |
Posted: 31 Mar 2021 at 12:00pm |
Just replace that flux capacitor thingy ma bob. One of the big chain parts stores on the south of the 49th added it to there inventory just for the trying covid times.![]() ![]() ![]() Edited by Ray54 - 31 Mar 2021 at 12:04pm |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 31 Mar 2021 at 8:23pm |
Found on 27 HP B&S the arm was bent and dragged - seems someone backed into some solid object and that readjusted clearance on carb setup , bent arm out and everything worked with governor actually control speed as throttle was moved
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Posted: 01 Apr 2021 at 11:59am |
well Jay, what did you find
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 01 Apr 2021 at 2:03pm |
I've got a Simplicity 61" Zero Turn mower. I used it for a couple of hours a couple of weeks ago, then parked in the shop, and build a trailer hitch for it, to pull a lawn roller, then a couple days latter put it back in the barn.
Sunday the guys came and got their boats out from winter storage. I wanted to move the ZT mower and it would not start. It has a B&S V-2. I talk to my dealer and they said to replace the fuel pump, I did and that fixed it. That sure is a strange fuel pump, It's not very big and seems more like valves. The engine also has a round thing mounted on it that fuel lines going through it, both feed and return. It's maybe 2" dia. and 6" long. Anyone know what it does? The mower is a 2013. It's a B&S engine. Dusty
Edited by Dusty MI - 01 Apr 2021 at 2:06pm |
jaybmiller
Posted: 01 Apr 2021 at 2:18pm |
well, tore it apart....NOTHING obvious.. 4 bits of guv look OK...cleaned, reassembled, used last of gasketmaker goop, have to wait overnight before I pour in the oil and fire it up.... had to make an engine lifting gizmo, mounts on crankshaft ontop of flywheel. Somehow I managed to get the balance point PERFECT, so at least something went right for me. Dusty... fuelpump is vacuum operated from a valve cover...real 'old skool' tech ! Be real careful pushing gaslines back on, else you'll break the plastic spigots and then have to spend anotehr $11 to buy anotehr pump and filter from China ( I now have 4 setes in stock.....don't ask why !' ) curious am I , about the 2by 6 'device'... please post a picture when you can...something I havent seen before You should ALWAYS shutoff gasline, run engine 'dry', to remove all the gas and water from the fuelpump. Winter has a nasty habit of freezing the water in the gas and busting those pumps....... OK NOW you know why I have 4 on the shelf..... Jay |
steve(ill)
Posted: 01 Apr 2021 at 2:29pm |
Dusty, is it some type of fuel FILTER ? Like Jay, i have never seen anything like you described.
jaybmiller
Posted: 02 Apr 2021 at 7:37am |
ARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRGH adjusted as per the official B&S manual.... left gasketmaker to set over night.... got on,started up ,idled ok(cold here). ran throttle up....won't go down ARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRGH anyone got some C4 I can have ??
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 02 Apr 2021 at 7:53am |
Jay,
Dont let this get the better of you. Its some little thing, spring on the wrong way? something hitting something else. Assembly slightly wonky. Do you have another unit near by that you can look at too? Just some basic things I do when something is not working. Did it work when he brought it to you? Dont have the answer here. Did you take pictures prior to the tear down? Regards, Chris
jaybmiller
Posted: 02 Apr 2021 at 9:53am |
arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrgh this is driving me NUTZ.. replaced the guvlever,springs,throttle mechanism(shouldn't matter but only so many straws in a bale, right) push out into the cold... starts up above idle....warm it up mid idle, has full, can throttle down to idle, high, med ,low, high....little rough but needs a 'good run'...as it sits, it 'seems' fine (been down this road before).. go for test drive, full out..down to driveway and back..... stuck at full throttle......same as before arrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrgh dang frustrating came in for a leaky oilpan gasket and starter....2 months ago... never EVER had one do this and everything looks/moves 'by the book'. one of life's mysteries I suppose IF I could find a rider with a 22-25HP engine, it'd be swapped out PDQ ohwell, off for a ride aroud the neighbourhood thanks for letting me vent... Jay
Kansas99
Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Posted: 02 Apr 2021 at 10:11am |
Jay, I once took a 4 wheeler to the dealer that wouldn't shift, he looked at it and asked me if I had a pickup I didn't like. I said yes at least one, he then told me to put the 4 wheeler in the back of the pickup and set the whole works on fire and collect insurance.
Just a idea. ![]() |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 02 Apr 2021 at 10:20am |
check the coils and make sure both are fireing and the diodes that go to the kill wire on the coils are not bad been there 10 years ago when our shop was replaceing alot of those crankcase gaskets we learned that you always replace the gov. assy. no matter what and now that is standard procdeure on all brands when we open the case
jaybmiller
Posted: 02 Apr 2021 at 2:52pm |
Hay Dusty... I'm thinking it's a samll 'reservoior' tank for the engine.... gas tank->fuel filter->reservoir->pump->engine
jaybmiller
Posted: 02 Apr 2021 at 3:00pm |
rear view....fuel filter in lower leftunder '71 of ruler.... owner's manual of machine 'should' talk about it,or a 'parts book' will..... Jay
jaybmiller
Posted: 02 Apr 2021 at 3:01pm |
..so now I'm reassembling my 22hp engine,course with the shutdown getting SAE30 oil will be 'fun' AND I need to find some parts 'next door'......
Dusty MI
Posted: 02 Apr 2021 at 5:49pm |
The manual doesn't say anything about it. It's sealed and it has a tube coming from the gas tank hooked to it and another one going to the engine. Also the tubes are not removal and the canaster is sealed. Thanks Jay for posting the picture. Dusty
jaybmiller
Posted: 03 Apr 2021 at 6:19am |
looks like the part...... some kind of 'pollution control' part.... while it might not be your EXACT unit...kinda looks similar.... Jay
jaybmiller
Posted: 04 Apr 2021 at 9:38am |
Ok, I cheated... bought a complete Craftsman PGT9000 (26HP Kohler/54" deck) for $800 one day, I'll get back to the B&S from Hell, maybe have to 'reassemble' my ridingblower and the other rider and TRY to find the 1 1/4" socket that's hiding in the garage..... oh well, it's sunny and getting warmer. Jay
