AC720 electric fuel pump?
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Topic: AC720 electric fuel pump?
    Posted: 25 Mar 2021 at 9:14am
NAPA employee search came up with Facet 40131N fuel pump 9452 for ~$140 from ebay. Printing on they original pump label has faded; appears to be PRMR(?).   Would appreciate knowing what others have experienced.  Herb(GA)
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2021 at 10:51am
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2021 at 3:12pm
I used on I bought off the internet as long as you leave the return line on so you don't put too much pressure on the carb any electric should work
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2021 at 7:05pm
I use a Facet model 40104 electric fuel pump kit on my 720's. You can buy online or at NAPA. It's a low pressure, I think it is 1.5 to 4psi.  I usually remove the original mechanical fuel pump and cap it off.  I also still use the return line.
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 6:19am
We offer a complete fuel pump kit if interested Herb. Visit our website. Our P/N 1703-22. Comes with mounting plate, fuel pump, relay, oil pressure sender, wiring and instructions.
Steve@B&B
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 9:34am
I think it was the spring of '14 we bought an A.C. 720 that had a replacement engine, the original engine was included, it's still in the cardboard. I don't see where I'll ever need it, so if anyone needs it, let me know.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 11:52am
Steve, I like your design of including an oil pressure sensor in the circuitry.
Dusty, thanks for your offer.  My 720 has been treated well and does not get much use so I do not expect many problems; mqy be some one else has a need for your used Onan engine.  Herb(GA)
