XT 190 |
dog catcher
Topic: XT 190Posted: 23 Mar 2021 at 7:55pm |
THROTTLE ON 190 WILL LET TRACTOR IDLE BUT WHEN FULL THROTTLE TRACTOR WAY OVER REVS HELP PLEASE
DrAllis
Posted: 23 Mar 2021 at 8:07pm |
Gas or diesel ??? How do you KNOW it's over revving??
calico190xt68
Joined: 12 Jan 2017 Location: Frankton, IN Points: 904 |
Posted: 25 Mar 2021 at 6:58pm |
I had something like this occur when my injection pump started to fail. The throttle lever would not control the engine RPMs and it would race on it's own, but I don't think the rpms went past 2300. What does your tachometer say when this happens? My tractor would also die off and on as the pump failed, so the failing pump created all kinds of issues. I had leaking fuel out of the timing inspection plate too. Anything else like that happening? I see you are fairly new so suggest you document as much as you can about the problem for the best help.
dog catcher
Posted: 28 Mar 2021 at 3:30pm |
just by sound of engine it is gas
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5469 |
Posted: 28 Mar 2021 at 3:38pm |
Gas engine has spark plugs, diesel has injectors. So which is it?
dog catcher
Posted: 28 Mar 2021 at 3:59pm |
it is a gas engine
MACK
Posted: 28 Mar 2021 at 8:48pm |
I would say misadjusted or worn linkage between governor arm and carburetor . MACK
