Battery box on a CA.
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Topic: Battery box on a CA.
    Posted: 23 Mar 2021 at 11:41am
The battery box on my CA measures the same as the battery box on my WD45. Are they the same? Any different mounting brackets needed? Thanks in advance for your help.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2021 at 1:35pm
Not the same they both mount differently. CA has 4 tabs on the bottom of the box that bolts to the sides of the torque tube.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2021 at 2:47pm
Nope not the same, and don't be surprised if the replacement you get has to be modified a little bit because the tabs won't match up to your tractor mounts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2021 at 3:13pm
Thank you! There's always helpful advice on the Forum! I appreciate it.
