Indicator light?
Neal (scMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neal (scMN) Quote  Post ReplyReply Direct Link To This Post Topic: Indicator light?
    Posted: 08 Sep 2010 at 4:00pm
The red indicator light on the lower left of the dash of my D-17 series 3 is lit. It comes on whenever I press in the clutch. It wasn't doing this until I changed the oil filters, hydraulic and engine. Is this normal and why did it start now?
FredW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 4:11pm
Mine does that also, why yours just now I have no idea. Fred
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 4:29pm
The lite tells you there is no/low pressure from the power director lube pump. When yiou step on the clutch the pump stops, so the lite should come on.  Why it didnt before you changed the filter, I dont know.  The sending unit for the lite is up there on the filter head with one wire going to it.    HTH
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 10:15pm
It is doing it's job.  Normal.
