Vicious Acceleration
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Topic: Vicious Acceleration
    Posted: 08 Sep 2010 at 3:38pm
My WC has been acting as any old tractor should until a few days ago. The problem is that after I start it, without touching the throttle lever that is at the slowest setting, the tractor will start to accelerate all by it's self until it is at full throttle. The lever does not move while it is doing this. the only way to slow it back down is to pull the lever back past the notches where it will slow down and  idle normally. It's to the point now that I drove up the road with the throttle wide open in only the second notch.
Any Ideas?
 Jeremy
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 4:02pm
sounds like something in the governor came apart.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 4:31pm
I second that .
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 5:23pm
OK So will this hurt the tractor? I want to get this fixed but I have no idea how to do this or what it might cost. The tractor should still be good to go to some shows like this, I hope.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 5:25pm
first thing I'd do is take the plate off the front of the distributor housing toward the radiator...your governor is in there....see if anything falls out, or is loose.....most likely a weight or spring....Im sure someone will chime in that has more experience than I.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 7:53am
If the govener weight falls off, it could break some teeth off the govener drive gear and/or cam gear...and get pieces of metal into the crank case. Pull the radiator and cover as discribed by Benny. A new distributer drive assembly (from Sandy Lake Implement) for my CA cost approx $150 a few years back; you may find previously used parts cheaper by advertising here or at your local tractor salvage yard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 6:31pm
I guess a magneto would have a different drive than a distributer.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 7:26pm
Here is a link to the pictures I took of the governor on my WC, it shows what you should find in there.  I agree with what has been said above you probably have broken governor weights.  You'll have to hope the chunks don't get wedged in the timing gears.  I found pieces of weights in the crankcase of mine when I first took it apart, and a good size piece of one behind the cam shaft gear.
http://home.comcast.net/~old_allis/ac-wc-gov.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 8:24pm
OH GOOD LORD!! That looks a little scary.
Hope I could figure it out.
Jamie (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 8:27pm
Tom, those pics are awesome! I always wondered how all that worked.
Just when I thought I was finishing my "honey-do-list", she turned the page!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 8:44pm
outstanding pics!
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 2:54pm
I have a question for you guys. I know the WC only has a top speed of 9.5 MPH which is too slow for most tractor drives. What would I need to do to the governor to let it go a little bit faster?
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 3:47pm
I think you already done it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 5:56pm
AC37, here's what DrAllis has posted before on the governor & I saved for posterity. Remember that spring AND weights combined make the difference.
Dr. Allis says:
I'm going to try and make this simple and to the point. Engine off....throttle wide open....adjust
(bend) the vertical governor arm such that the carb link rod just slides into the arm hole or be even
1/16" too short. DO NOT EVER DEVIATE FROM THIS SETTING!!! (1/16" short will not affect the HP output).
This is making the governor as "quickly" acting as it can ever be while still allowing for full open at
the carb. If you need more (or less) rpms change the spring/plunger inside the governor OR add an
external spring like I said earlier to the governer vertical arm, remembering to make the extra spring
as long as you can and keeping it down low (1 to 2 inches max from the bottom) on the arm.
Some of the 201/226 engines have a high idle rpm stop screw/bolt on the top of the governor front
cover to be able to adjust rpm's some, but not 200rpm  at a time.
Governor springs as I know of ..
WC-1600 rpm tops
WD/WD45-1700 rpm
170/175-1800 rpm (only with WC/WD/WD45/D17 governor weights!!!)
D17-2000 rpm
D17 spring with 170/175 weights-2200 rpm
These rpms numbers are close and will vary a little bit with the carb you are using and even cubic
inches and camshaft style, but they are accurate in the results you will get from slowest to fastest.
There are possibly a couple of other springs for other applications listed in the parts books.
There are THREE different 201/226 governor weights....
 - Gleaner E/E3 combine is p/n 70236562 (I have two pair in my hands as I write this)
 - 170/175 weight (which I have no p/n)
 - WC-WD-WD45-D17 weights (which I also do not have a p/n for.
Different strength springs control the maximum speed and to a small degree droop. If you had these
three DIFFERENT weights in your hands you would see the difference in the design of the fulcrum on each
one.
I've just been on AGCO's website for parts books and here's what I found....
WC-WD-WD45-D17 governor weight is p/n 70229980 with a 70229519 gov spring/plunger...
170-175 governor weights are 70248572 with a 70226785 gov spring/plunger and finally
E-E3 Gleaner weights are 70236562 and the spring (without a plunger) is 70236564.
I've always used E-E3 weights on my pulling engines. They have the least amount of droop by design of
the fulcrum......combines need to run a steady speed for the seperator to work properly. If you're
happy with your setup, stick with it.
WD45 springs will get you 1700 rpm tops and D17 springs will get you 2000 rpm tops.....I don't know
what the paint stripe code is/was.
If you start lengthening the carb link rod, you will deaden the governor !!!!!(now the droop will be
400 rpm) that length is critical to governor quickness. Hanging an extra spring on the block drain to
vertical arm is a way to increase rpms and still have things work correctly....just use a long spring
and keep hooked low on the gov arm...maybe an inch to two from the bottom.
The 200 rpm "droop" on 170-175 models (2000 down to 1800 full load) is due to the design of the governor
weight itself, not the governor spring. Governor weights are the same for WC-WD-WD45-D17( and have a 300
rpm droop).  The 170-175 are different(and are a 200 rpm droop). The E and EIII Gleaner are also
different and are 150 rpm droop approximately.
Edited by CJohnS MI - 10 Sep 2010 at 5:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 8:10pm
After all that good info, I would advise not to try and make your tractor run faster than it is supposed to unless you KNOW there is no ridge in the cylinders. If you want the tractor to go down the road a little faster, put taller tires on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 8:14pm
Yeah, I see where that can be risky
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 8:16pm
Another option to make it go faster is find a Sherman step up transmission.  I don't know how much faster it goes but I think it would get you to caravan speeds.  Mine goes fast enough with 13.6 X 28 rear tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 8:20pm
I've never seen a Sherman on an Unstyled WC. Aren't those like needle in haystack rare.
This page was generated in 0.043 seconds.
