ALLIS CHALMERS "D" ROAD GRADER STARTER
Josh S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh S. Quote  Post ReplyReply Direct Link To This Post Topic: ALLIS CHALMERS "D" ROAD GRADER STARTER
    Posted: 19 Mar 2021 at 10:48am
I have a "D" road grader serial number "D-258"
Starter keeps binging up, tried a new starter that had same tooth count as old one "10" and it also binds.
Curious if anyone can tell me what year this machine is and what starter it needs. looks like it should be the same as a "WD" Allis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2021 at 5:44pm
1949. Should have W201 motor. gotta be careful there, sometimes the 201 gets replaced with a 226.  Don't know what starter goes with what motor, or if they are the same.  I would get a real good look at the ring gear, and also turn the motor over a couple times by hand, to make sure nothing binds, and to carefully inspect that ring gear...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2021 at 6:56pm
10 tooth should be right.. Did you try a "NEW" starter or just a different one ?  Old BENDIX can be a problem with  binding.
