generator
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Topic: generator
    Posted: 19 Mar 2021 at 3:34am
del peterson auctions March 23rd, 150,000 watt genny powered by Allis Chalmers engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2021 at 6:32am
great...someone else buy it fast ! Otherwise that dang 'machine' will be on 24/7 ALL winter long !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2021 at 12:25pm
That be one BIG HOSS !
Edited by steve(ill) - 19 Mar 2021 at 12:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2021 at 11:56pm
what size was "BIG AL"?
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2021 at 7:08am
Does anyone have any idea what that genny would weigh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2021 at 7:18am
That is "Big Al" in a gen set configuration, probably without intercooler and less HP.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2021 at 7:30am
844 cu in for the big Al engines.
The engine is a 17000 model, lightly turbocharged, with 325 hp. The 25000 was 450 hp.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2021 at 8:47am
If I win the lottery tonight, it'll come to my house! Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2021 at 1:46am
it's not called "winning the lottery" Darrel, it's called "winning the bid"!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2021 at 1:47am
prolly the best shaped "big Al" anyone would see nowadays.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2021 at 2:51am
It definitely looks like a dandy! Should run forever, being it hasn't been putting out the big horsepower.
Darrel
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2021 at 8:52am
To yield 150kw out, the engine will need to develop about 240hp. I can't read the tags-is it a 4 pole (1800rpm) or 6-pole (1200rpm) unit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2021 at 9:10am
It is a 17000 series 844 CID motor so 1800 rpm..  150 KW really closer to 201 HP.
It has a jumper panel to set to any voltage output and single or 3 phase..
Edited by steve(ill) - 22 Mar 2021 at 9:18am
