Allis Chalmers 840C wheel loader starter
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 840C wheel loader starter
    Posted: 15 Mar 2021 at 4:22pm
Hey y’all
Would anyone know where to get a starter for a Allis Chalmers 840C wheel loader?
From the research I’ve done they was imported from Japan and only 100 of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 5:26pm
Have you tried googling mitsubishi 270 cu in diesel motor starter?Wink
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2021 at 3:38am
Take it to your local starter/alternator shop, they should be able to fix you up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2021 at 10:14am
Well the problem is that it melted the cap off.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2021 at 8:01pm
Some references - might not help.
https://www.allischalmers.com/forum/840-wheel-loader_topic8666.html
Older Mitsubishi trucks around 1980 seem to have Denso starters (6DS7 engine).  Later ones Mitsubishi (6D14) but they're bigger than 270 cid.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2021 at 7:40am
I have a 840c with bad brakes I would sell the hole thing just don't use it enough
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2021 at 6:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2021 at 6:54pm
Thanks, that helps me a lot!!!!!
