7GB injection pump removal
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Topic: 7GB injection pump removal
    Posted: 12 Mar 2021 at 7:51am
This machine is getting fuel in the oil pan. Need to pull the pump. It has the 3500 engine, DC roosa pump. That should be a non retained shaft correct? Does the oil cooler need to come off of the engine?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2021 at 9:02am
oil cooler should be able to stay, but when I pull DC pumps off D21/210/220 tractors, I take front access cover off allowing the shaft and gear to go out the front, cutting the seals off shaft so it will pass through the bushing. Not positive yours is same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2021 at 2:19pm
Thanks Ed. I see it now. I had to use a mirror to see the front of the engine. Plate isnt round like the tractors are.
7G-B owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7G-B owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2021 at 12:45pm
Where is the injection pump?  I've read on one of these forum posts that the tandem hydraulic pump was near it.  I'm having steering and transmission shifting issues.  :-(
