D19 Hydraulics
bpatterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bpatterson Quote  Post ReplyReply Direct Link To This Post Topic: D19 Hydraulics
    Posted: 07 Sep 2010 at 9:58pm
Hi everyone
I just aquired a D19 gas tractor it runs ok but the hydraulics are giving me problems. There are three levers to the left of the seat the one closest to me raises the 3point but once it gets all the way up it stops and releases the three point back down. If anyone has any thoughts please let me know. Ther is also a lever on the steering wheel below the traction booster lever that seems to be involved with the process of raising the rear hydraulics.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 10:56pm
Pretty common problem with the D19...the check ball and seat in the valve assembly need to be replaced. You have to take the valve apart to get to it as it is between the two halves. Lever by the steering wheel is the depth control.
ALLIS EXPRESS!
This year:
