Wobble |
Post Reply ![]() |
Darrell G (MN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Green Isle MN Points: 1496 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Mar 2021 at 2:02pm |
A friend of mine has a 8N ford and after about 8-10 mph the front wheels go into a death wobble, any ideas on how that can be fixed.
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 10915 |
Where does the wobble start at steering box or tie rod ends
Tie rods are solid, I think it starts inside the gear box
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87885 |
adjustments inside the gear box .........
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3583 |
Steve has probably got the info on it. Back in my day as a youngster, when you wore the box out that far you put your two feet up on the steering shafts and let her rip.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54135 |
Hadda MF turf 20, like that, it would do 30-35 mph, with the road gears it had in it. Wobble started in the upper range! Maybe its time fer the universal ford fix! ![]() |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5107 |
I've always heard the way to fix a Ford (no matter what the problem) was to first find an abandoned quarry. Then tie the steering wheel of said Ford pointed in the direction of the abandoned quarry. Then after starting the Ford (if it will run, if not, push it), put it in gear and bail off
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
X2 with Paul!
Post Reply ![]() |
