Truck bed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Topic: Truck bed
    Posted: 27 Feb 2021 at 6:53pm
Was looking at the bed on my 89 F250 while I was at the farm this week and it appears that the center part may be a separate piece. Does anyone know if that section can be removed without removing the entire bed? Sure would make it easier for a fat old guy to get to the fuel tank selector valve and plumbing rather than crawling under the truck.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 8:57pm
Not sure about a Ford but, I have worked on Chevy & Dodges— 15 min and the bed will be off. Takes to for lifting off.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 9:05pm
I am sorry to tell you my friend, but it is spot welded in
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 9:10pm
Well, he still has to crawl under the truck to remove the bed. and it would take four of us old guys to lift it off! LOL
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 10:29pm
the BIG problem is the 6 bolts that go thru the floor into the frame.. Might take 15 minutes, or 2 hours to get them off !! ...... Once they are off, tail light wires, gas tank hose, axle vent, etc... and ready to lift off... I park under a barn beam and use a couple  little cable come alongs to inch it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2021 at 6:10am
Thanks for the responses. I was hoping to get by without having to remove the bed but hadn't seen any information on doing that. Looks like the come alongs will be the easiest route.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2021 at 8:59am
I put one come along on the front left and one at the right rear.  Used a hook into the pocket at the corner.. The other two corners i put a 3/8 inch nylon rope.... Crank the bed up 6 inches, then tie the ropes to stabalize from tipping.. Crank up another 6 inches, tie ropes again.. Park in a good area so when bed is up a foot, you can push or pull it forward 10 ft to get away from the bed......... work on truck, then push back into position and lower bed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2021 at 9:28am
Look at the bright side— if everything is rusted, it will be replaced when you fix the sending unit. The first one I helped with, I thought it was going to be a major job.. not at all. If you had a 2008 Chevy, you would get to do it every few years .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2021 at 10:53am
Grind the heads off the 8 bolts,undo the filler necks, wiring harness,maybe a ground strap.either crane or forklift the bed off.
if you heat the bolts@ the 'nuts' you MIGHT get 1 or 2 off,though most snap...then well,now you know why I said grind the heads off
I've done this to maybe 25 to 30 pickups in the past 10-12 years
When you're ready to reattach, be sure nuts are good, use lots of neversieze ,and of course new $$ bolts....
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2021 at 11:29pm
blue tool?
This page was generated in 0.122 seconds.
