Hydraulic Cylinder End Cap
bauerd44 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bauerd44 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Cylinder End Cap
    Posted: 27 Feb 2021 at 3:13pm
On my AC 500 loader, the lift cylinder gland nut at the end where the rod come out, is always backing out, and if I don't see it, I am going to have a mess.
How tight do you make the nut.  I have always used a screw driver to tighten up. I do not have a spanner wrench that will fit.
Thanks   Dale
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 7:28pm
use a hammer and punch , get it tight.           MACK
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 11:54pm
You can make a spanner wrench by cutting with a torch and then drill holes to fit your needs. Fit pins to size. Weld in place. We have made several this way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2021 at 6:02am
no torch ???... cut 3 pieces of flat bar, weld into a 'U'(inside of u just bigger that OD od ram., add a handle...looks like a 'Y' or goalpost now.. fun part weld tabs ont he unprights of the 'U' to fit the 'pinholes' of the nut.
One of those ,after it's built ,it's easy to see HOW to make one......
