WTB log carry |
Hunt4Allis
Topic: WTB log carryPosted: 24 Feb 2021 at 6:31am |
need to move some trees without dragging them so hoping to find a log cradle/ carry?
Jim.ME
Posted: 24 Feb 2021 at 7:24am |
Are you moving complete trees to replant, or moving logs cut from trees? What are you using to pull this with?
Hunt4Allis
Posted: 24 Feb 2021 at 7:50am |
logs already cut laying on ground...
AC d-17 that has a pig pole lifting arm on rear to position them.
Jim.ME
Posted: 24 Feb 2021 at 8:35am |
An arch commonly used behind crawlers, with winches, lifts one end, so the logs drag easier and minimizes dirt on the logs. If you want the log totally clear of the ground and have a D17 that will pick them, use a narrow single axle woods trailer. Make one from an old pickup frame, no deck, mounted direct to a pick rear axle with the top of the frame rails even with the top of the tires, or narrowed house trailer type axle. Put a stake pocket (make stakes removable) at each corner. Remove the stakes on one side, set logs on lengthwise, put the two stakes back in and go. I have a single axle one and a tandem one I use mainly for 4' wood, but have moved logs on them.
I have seen frames to carry logs by hanging them below the frame, usually sold for 4 wheelers. Personal opinion, I think that a woods trailer is an easier way to go than lifting to hang logs on chains under a frame (then you have to unhook them as well), if you want to carry them clear of the ground. I also think hanging up and dropping them off that type carrier has more risk of injury. And the trailer can be used for other things than logging.
Edited by Jim.ME - 24 Feb 2021 at 10:02am |
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 24 Feb 2021 at 9:21am |
I wonder if an old propane tank hauler would work?
I have used a wagon running gear, put taller stakes on sides if needed. Edited by JoeO(CMO) - 25 Feb 2021 at 9:34am |
Dakota Dave
Posted: 24 Feb 2021 at 10:59am |
Dad made a dray back in the 70s 2 16' logs barked on bottom angle cut in the front. Had boxed 7' cross pieces welded to 16' thick handle irons lag bolted to the logs round pockets every 4' where the cross pieces were. Pull the stakes and roll the logs on we could stack logs 4-5' tall and pull out of the woods with the budozer. Kept logs clean. The logs were put on a trailer and hauled to grandpa's saw mill. One load more than we should have hauled on two trips behind the pickup. Poor little 250 strait six struggled with half what we could put on one day
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 25 Feb 2021 at 8:00pm |
I use an old Brindle propane
HD6GTOM
Posted: 25 Feb 2021 at 10:29pm |
I hauled a lot of lp tanks on one of them. It gets a bit harry with a 1/2 full thousand gallon tank on them. Only did it once, was a repo situation.
