Log carry? |
Post Reply ![]() |
Hunt4Allis ![]() Orange Level ![]() Joined: 13 Mar 2018 Location: Ohio Points: 1172 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Feb 2021 at 6:27am |
anyone have one they want to sell? I've seen these used/pictures shown of using but never for sale?
Even an old axle with good tires would work as I can weld up the u shaped cradle to go onto... Pm me please, thanks fellas!
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88081 |
how about an old trailer... trailer axle... rear axle from 1/2 ton truck..
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2680 |
I think littlemarv made one. Maybe he would chime in?
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
I'm not sure how much weight they will carry, but a rear axle off of a front wheel drive car is clean straight axle. Depending on how big the log is, I've put a chain around a log and around a blade or drawbar on the three point and got the end off the ground.
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2269 |
A true log arch has no straight axle between the wheels....the wheels are attached at each end of the arch itself. The straight axle would be in the way.
JK in Pa ![]() Bronze Level ![]() ![]() Joined: 12 Sep 2009 Location: Dushore, Pa. Points: 164 |
Check Northern Tool.
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3564 |
Do it yourself log carrier.
https://m.youtube.com/watch?v=qzbL8mhPi2U |
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3091 |
AKA as a swing cart a lot of places.Make one out of an old fertilizer tank carrier and get a couple 12V winches to lift the logs.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54220 |
The one I made, I used the bottom frame from a 300 gallon sprayer, put 20" bus tires on it. I made a sloping piece of 1" diameter stock, from the front tongue up and over the frame. Used a sliding clevis on the round stock, to lift the log, as you pull forward. that way, you back into the log, hook chain up to the front of the log, as tight as you can, jerk forward, and the log lifts itself up, on the front end!
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
i use an old propane tank carrier, it's open between the 2 wheels and the top is strong, i used a 12V winch to do the lifting, can tow behind a tractor or pickup.
littlemarv ![]() Orange Level ![]() Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Oh boy, here you go. My adventures in logging thus far....
Personally can't wait for this spring to try out everything I've been scheming on this winter. |
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5902 |
To obtain an old Axle for cheap, visit an RV Repair Shop and get an "slightly out of alignment' RV Axle, the result of hitting a Pot Hole. G |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4094 |
Quote; littlemarv
Personally can't wait for this spring to try out everything I've been scheming on this winter. I'm with you 100% on that! Stupid snow and sub zero temps. have been a drag. Several more trees that need felled.....
Edited by IBWD MIke - 25 Feb 2021 at 9:41am |
Post Reply ![]() |
